Using EK suspension on an EG
Old May 8, 2002 | 01:36 PM
Todd00's Avatar
I said I don't want a title!
Default Using EK suspension on an EG
I know the front EK suspension will bolt right up to an EG, but what about the rears? Can I use an EK LCA bushing or something on the EG LCA to make the EK stuff work properly?
I found a good deal on some EK stuff, so that's why I'm wondering.
Old May 8, 2002 | 02:18 PM
owen_the_soyboy's Avatar
Default Re: Using EK suspension on an EG (Todd00)
you sure do get some wacky questions man....
I have heard of people using EG suspensions on EK's, since the EK has smaller/thinner LCA's.
try contacting Energy Suspension / Prothane maybe they can get you a poly bushing the right size to fit your EG LCA and a metal sleeve that will fit the shocks properly?
Old May 8, 2002 | 04:49 PM
vpc's Avatar
vpc
New User
you'd have to modify the rear forks on the shocks to work w/ the eg lca. People do wierd things on this board *scratches head*
Old May 8, 2002 | 05:01 PM
GokuSSJ4's Avatar
Default Re: Using EK suspension on an EG (vpc)
why not do type R and change the rear LCA
Old May 8, 2002 | 05:05 PM
acuracing's Avatar
Default Re: Using EK suspension on an EG (Spoon1)
Go the 5-lug route! But if you do make sure to upgrade your master cylinder...
Old May 8, 2002 | 05:07 PM
GokuSSJ4's Avatar
Default Re: Using EK suspension on an EG (acuracing)
or at least the proportion valve , makes a difference
Old May 8, 2002 | 05:12 PM
sparkz's Avatar
the fronts from thr ek will fit the egs no problem but its the rear that doesnt. all you have to do is sand down the rear bushing to accept the smaller rear fork of the ek. use a die grinder and it should take about 5-10 minutes to grind down each side.
i had to do that to fit ek stuff on my ef. (ef and eg have the same rears)
Old May 8, 2002 | 05:27 PM
93dx--hatch's Avatar
Default Re: Using EK suspension on an EG (sparkz)
what does lca mean?
Old May 8, 2002 | 05:35 PM
Optiks.'s Avatar
Default Re: Using EK suspension on an EG (93dx--hatch)
what does lca mean?
lower control arm
Old May 8, 2002 | 06:18 PM
Todd00's Avatar
Before you pass judgement--I have my reasons for doing this, ok? No, I can't do an ITR LCA because changing the LCA is against SCCA rules for this particular car. However, changing bushings *are not*. And all of the good coilover systems from JDM land use either the ITR LCA or are made for EK's. Good enough of an explanation so far? Believe me--I *know* what I am doing and I have a purpose in mind. Go flame some riceboy or something.
So can I just modify the bushing on the EG LCA to accept the EK stuff? Is there any difference in shock length or anything because that's my main concern.
[Modified by Todd00, 10:19 PM 5/8/2002]
Old May 10, 2002 | 11:07 AM
Todd00's Avatar
ok, up one last time
Old May 10, 2002 | 11:20 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I used some Koni Full coil-overs for an EK on my EG and here's what you have to do:
If using stock 1992-1995 lower control arms, you will need to trim the bushing where the strut bolts to the LCA.
The EK stryts have more narrow forks at the bottom of the struts, therefore this is why you must trim down the EG LCA.
ALSO:
If you guys don't know the answer to a question, why even post bullcrap about it?
I had a specific reason for using EK sus on my car just as Todd00 probably does too.
Would you pass up $1,300.00 Koni full coil-overs for only $300 just because they were for an EK?
If you did, then you are a moron.
Old May 10, 2002 | 11:25 AM
Todd00's Avatar
Default Re: Using EK suspension on an EG (B18C5-EH2)
ALSO:
THANK YOU for a legit answer sparkz and B18C5-EH2. This is all I was asking for.
[Modified by Todd00, 3:29 PM 5/10/2002]
Old May 10, 2002 | 11:37 AM
todaCspec's Avatar
i've checked the part #'s for Koni coilovers for 92-95 civic and 96-00 civic,they the same part#.i was wondering why the Koni does not tell you that you would need to shave the bushings a little?
Old May 10, 2002 | 11:56 AM
Thrashin's Avatar
when i had my eg i used apexi n1s for an ek on it, i did this because i got a 3 month old set from a friend for 700 bucks. all i did was trim the rear bushings just like everyone else said. they worked great and i never had any problems
Old May 10, 2002 | 01:19 PM
spoon_ek9's Avatar
[QUOTE]
[QUOTE]
sometime, SCCA get some stupid rule whats the different between the itr and EG LCA? its same length, same distance between bolt,but just a little bit difference in design and material.
Old May 10, 2002 | 02:00 PM
Todd00's Avatar
Default Re: Using EK suspension on an EG (spoon_ek9)
I know, but you can't write particular rules for certain cars. For all the SCCA knows, the ITR LCA will give you better suspension geometry and therefore make you faster. I can see their point.
In certain classes, you can change the LCA, but you can also change a lot of other stuff--thus making the class a very fast and expensive one to run in (Street Mod). Lower classes = less mods = less money, which is fine with me at this stage in my life.
Old May 10, 2002 | 03:38 PM
spoon_ek9's Avatar
well, of course, rule is rule, but i dont think the LCA is a big deal on the fair issue. its not like changing the whole car suspension geometry (eg,changing the way the suspesion be placed or something like that). on top of that, the class distribution of SCCA is kind of suck, how the hell scca put a car compete in the same class with other have more than 1000cc in displacement.(let say in T1 or T2).
Old May 10, 2002 | 05:33 PM
tonyxcom's Avatar
the front forks on a 99-00 si are wider then then everyother ek. So maybe you can get those forks and not have to shave your front lca.
The rear lcas wont fit at all, they are longer then the eg lcas. But i dont know about the shock mounting on an ek versus an eg.
Old May 10, 2002 | 06:07 PM
spoon_ek9's Avatar
Default Re: Using EK suspension on an EG (tonyxcom)
well, the front fork have to match with LCA, the reason why SI have a different fork is it got a bigger front LCA. in the case of todd, shock and spring only, it doesnt matter.
Old Jun 13, 2003 | 08:26 AM
EG4's Avatar
EG4
I dun suppose anyone has a pic of a shaved of the LCA?
i have the same opportunity wif sum EK goods and i was thinking whether this was worth the trouble?
Old Jun 13, 2003 | 08:40 AM
fortynineR's Avatar
Default Re: Using EK suspension on an EG (EG4)
how about integra rear and front lca's?... i have a set of front and rear lca's with poly bushings for an integra and a set of apexi 99 spec coilovers for an ek. can i use these for an ek? eg? or an ef?..
Old Jun 13, 2003 | 08:48 AM
fcuked's Avatar
Default Re: Using EK suspension on an EG (fortynineR)
Yes it works with slight mods.
Old Jun 13, 2003 | 08:59 AM
B18c1turboedEK's Avatar
Default Re: Using EK suspension on an EG (Junior.)
I know i got a set of brakes off an ek. I just bent the back forks a little to make it work. And ride like a beauty after i got my aligment yesterday..
Old Jun 13, 2003 | 09:37 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
I had CTR Apex'i N1 suspension on my 4th hybrid that got stolen. Worked without a problem.
