Upgrading master cilinder
Old May 8, 2002 | 01:21 PM
REX VT's Avatar
Default Upgrading master cilinder
Which one can I use to replace the 1991 SiR's master cilinder?
Thanx!
Old May 8, 2002 | 01:35 PM
Doctor CorteZ's Avatar
Default Re: Upgrading master cilinder (REX VT)
90-93 non-abs integra
Old May 8, 2002 | 01:54 PM
See Are X's Avatar
Default Re: Upgrading master cilinder (Doctor CorteZ)
I got an extra one if you want to buy it.
Old May 8, 2002 | 02:12 PM
RyanR's Avatar
Default Re: Upgrading master cilinder (See Are X)
Too bad the 90-93 Integra cylinder doesn't bolt up, you'll also need the 90-93 integra booster. Get a 90-91 Civic EX master cylinder.
Old May 8, 2002 | 02:14 PM
REX VT's Avatar
This is the integra with the b16 in it and the 262mm front rotors?
Mmm probs thesame I have now.
I was wondering if one from the Accord or GSR would fit
-> thanks for the offer
Old May 8, 2002 | 02:16 PM
RyanR's Avatar
GSR will fit fine, but you have to upgrade the brake booster. And unless it's a 98+, you'll have to reflare one of the brake lines.
Old May 8, 2002 | 02:26 PM
REX VT's Avatar
Default Re: Upgrading master cilinder (RyanR)
And the one from the Accord (Aerodeck) VTEC?
Old May 8, 2002 | 02:39 PM
RyanR's Avatar
It would probably fit fine. I had a prelude master cylinder on my CRX before and it fit fine except I had to cut and flare one of the lines. Like I said before, the only larger one that will bolt up fine is the 90-91 EX. Just go get one.
Old May 8, 2002 | 02:43 PM
REX VT's Avatar
What prelude model was that?
I'm pretty sure the 90-91 EX master cilinder is thesame I already have since it has the same brake system
Old May 8, 2002 | 02:52 PM
speedlimitR's Avatar
yeah...
i have 95 gsr front breaks and my stock 90 si rear disk. and i am useing a 91 civic ex master cylinder. i am not sure if it is biger or not. but it works fine, i dont have more thena inch of play and my breaks are super cherry! so that would work good!!!
but if you want to upgrand you master, liek i wanted to. i got a 2000 SI one, but forgot to ge tthe break boster, but if you get the boster and master, it will bolt up to your car. but you have to run the break lines around to teh other side of teh master. its not to hard. but kinda a pain.
if taht helps any cool. if not... sorry.
tRex99
25
Feb 27, 2005 04:24 PM
JobberRadio
15
Nov 30, 2004 07:13 AM
K-Drum
Jul 17, 2004 09:24 AM
Bnjmn
10
Dec 8, 2002 03:08 PM
gaskleppie
Nov 4, 2002 05:26 PM
