After D16Y8 CAR NOW STARTS BUT WONT STAY ON?
Old Nov 18, 2006 | 07:29 AM
92EG8's Avatar
Default After D16Y8 SWAP CAR STARTS BUT WONT STAY ON?
Finally after all the headaches...problems...issues...my D16Y8 inside my 92 EG 8 SDN i finally got it to start today. Ok i got it started but i have many problems ahead i guess... MY car starts wen u floor it half way and it will start and rev 1,500 to 2,000 almost like a bad IACV would...now if i release the gas it will live for a couple of second were it fights to stay alive at 500 rpm and die... The engine will not accept any type of throttle response... my car will not rev higher then 2,000 and its not responding to any throttle at all..So i have a CEL and i know i would i have a couple of sensors d/c )(V-tec Solenoid , Purge Solenoid) Also im using a B7 harness on a P28 ECU.ALSO MY TIMING IS NOT SET I HAVENT DONE MY TIMING IS THIS A BIG PROBLEM TO MY CAR NOT STAYIN ON WITHOUT GAS ?
Modified by 92EG8 at 8:44 AM 11/18/2006
Old Nov 18, 2006 | 07:49 AM
deadline's Avatar
try setting up the timing.....then go from there...
Old Nov 18, 2006 | 09:09 AM
92EG8's Avatar
ok so do timing
Old Nov 18, 2006 | 09:17 AM
-JSpecEk*9-'s Avatar
Default Re: (92EG8)
are you sure you didnt switch the tps and map sensor plugs? give that a try also
Old Nov 18, 2006 | 10:14 AM
92EG8's Avatar
**** i forgot that eg had the mapsensor on the chassis and the y8 had ito n the manifold yeah so i got both sensors in the right places i had the TPS without anything
i just connected the correct sensor to the map and the TPS thanks EK but now I need to know my firing order on a B7 dizzy on a Y8 engine
Old Nov 18, 2006 | 10:26 AM
Default Re: (92EG8)
remember #1 piston is always the one next to the timing belt.
Old Nov 18, 2006 | 11:16 AM
92EG8's Avatar
Yeah i know I went ahead and messed around with my firing because it looked out of order now its sputtering almost about to fire but wont fire up
Old Nov 18, 2006 | 11:21 AM
Default Re: (92EG8)
you sure there in the right order?
Old Nov 18, 2006 | 11:28 AM
92EG8's Avatar
No i actually im not confident at all they r in the right order
Old Nov 18, 2006 | 11:47 AM
Default Re: (92EG8)
ok give me a few mins and ill help you out
Old Nov 18, 2006 | 11:51 AM
Default Re: (JDMEK-9)
forgive me for the colors but it will get the job done haha
92EG8's Avatar
up
Old Nov 18, 2006 | 06:37 PM
92EG8's Avatar
WAt does that counterclockwise rotation mean? I will try again tommorow to start her up
Old Nov 19, 2006 | 08:20 AM
92EG8's Avatar
up i havent been able to start my car again after i changed the sensors around will this solve me problems
Old Nov 23, 2006 | 03:15 PM
92EG8's Avatar
up
Old Nov 23, 2006 | 04:09 PM
s_vares's Avatar
Sounds to me like a TPS problem.
Check MAP and TPS make sure not backwards
Old Nov 23, 2006 | 07:38 PM
92EG8's Avatar
Yeah s_vares they were changed up I fixed that. But thanks for everyones help especially
JDM EK 9 it was that my timing was off car started in one second . Thanks everyone for their input and troubleshooting help problem solved
ekboost350
13
Jul 27, 2013 12:25 PM
turbo'ek562
Feb 7, 2013 07:47 AM
Inliner
Sep 14, 2006 02:56 AM
CRXCRAZYD16Y8
Feb 7, 2006 04:09 PM
zakaria103
Jun 11, 2005 08:11 PM
