B serie oil pump gears Q?
Old Nov 18, 2006 | 02:51 AM
cvp467's Avatar
Default B serie oil pump gears Q?
Which oil pump comes with 84mm gears?
Old Nov 18, 2006 | 03:04 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: B serie oil pump gears Q? (cvp467)
i would like to know as well.
Old Nov 18, 2006 | 09:48 AM
Aggressive Racing's Avatar
Default Re: B serie oil pump gears Q? (turbotypeR)
I might be wrong on this,but to my knowledge i think its only the JDM oil pumps that come 84...
Old Nov 18, 2006 | 10:47 AM
DaveF's Avatar
Default Re: B serie oil pump gears Q? (Aggressive Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aggressive Racing &raquo;</TD></TR><TR><TD CLASS="quote">I might be wrong on this,but to my knowledge i think its only the JDM oil pumps that come 84...
but it is type-R specific
Old Nov 24, 2006 | 03:13 AM
cvp467's Avatar
Default Re: B serie oil pump gears Q? (dturbocivic)
bump
Old Nov 24, 2006 | 07:18 AM
Jared's Avatar
Every OE pump I've ever bought from a dealership has 80mm gears.
Old Nov 24, 2006 | 08:09 AM
earl's Avatar
Default Re: (Jared)
15100-P72-A01
Old Nov 24, 2006 | 08:50 AM
RACEPAK's Avatar
Default Re:
what do you need that for?
Old Nov 24, 2006 | 09:02 AM
cvp467's Avatar
Default Re: Re: (RACEPAK)
because I got a 84mm TODA oil pump gears.
Old Nov 24, 2006 | 08:07 PM
25 Year Member
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">15100-P72-A01</TD></TR></TABLE>
just got one.it was 80mm
Old Nov 25, 2006 | 09:53 AM
earl's Avatar
Default Re: (turbotypeR)
This is the best Honda has. It has an 80mm diameter and the max thickness available. If there has ever been an 84mm pump, I think it would have to be aftermarket. I can't imagine an 84mm pump to be able to put much more oil into the motor. There are different thickness oil pump gears, which can make a large difference, however. If anyone knows about an 84mm oem housing, please post info and part #.
Old Nov 25, 2006 | 10:03 AM
Jared's Avatar
That would be nice. Toda lists the 84mm gear as Type R, but I have yet to crack open a B oil pump that has them.
Old Nov 25, 2006 | 01:31 PM
cvp467's Avatar
Default Re: (Jared)
Thanks for your help guys
Old Nov 25, 2006 | 01:51 PM
25 Year Member
Default Re: (earl)
i don't think it pumps anymore oil. i think the outside diameter is bigger.
cvp467
Nov 25, 2006 01:33 PM
vtec-gorilla
Sep 1, 2006 09:05 PM
djnikko
Nov 18, 2005 09:05 AM
StolenTeg
Oct 3, 2004 06:50 PM
SikofFalln
23
Jul 8, 2004 10:28 PM
