FS: GReddy E-manage Ultimate & Boomslang PnP Harness
Old Nov 18, 2006 | 12:47 AM
TimeRacer's Avatar
Default FS: GReddy E-manage Ultimate & Boomslang PnP Harness
I'm selling a GReddy Emanage Ultimate system that comes with a Boomslang plug and play harness. This system is better than any V-AFC as it controls ignition timing and fuel trim settings directly and this system includes data logging of almost any OBDII sensor. The system is complete and already setup for any 4cyl Honda with VTEC but can be setup for almost any car.
The Boomslang PnP harness is for OBDIIa found in Civics, 96-98 Integras, and all 5th Gen Preludes. This system is already setup and can be installed in around 15 minutes.
This system is perfect for anyone who wants to pass OBD SMOG or wants to keep their ATTS system.
GReddy E-manage & PnP harness & 6ft USB cable & A/F attachment: $625 shipped
Willing to sell the main unit itself for $430 shipped if you're interested.
- FUNCTIONS
Airflow Correction :
Airflow Adjustment Map / Airflow Output Map / Boost Limiter Cut Map / Anti-Engine Stall Map.
Injector Correction : Injector Adjustment Map x2 / Acceleration Injection Adjustment Map / Individual Cylinder Injection Adjustment / A/F Target Value Map / Vehicle Speed Correction Map, Coolant Temp Correction Map, Intake Air Temp Correction Map / Rev Limiter Cut
Ignition Adjustment : Ignition Correction Map x2 / Acceleration Ignition Map / Individual Cylinder Ignition ADJ Maps / Ignition Cut Feature / A/T Shift Compensation Feature
Others : External Output Map (VTEC) / NVCS Control Map / Analog Output Map / Idle Stabilization Map
- ADDITIONAL FUNCTIONS
Serial Port : External Data (such as GReddy Warning Meters & other future optional products) can be monitored and recorded in real time through a data link cable.
Switch Port : Data Logging & Ignition Cut features can be activated with the use of an optional Remote Switching System & Switching Harness
Option 1/2 : GReddy Pressure Sensor, GReddy Temp Sensor, A/F Input Harness, Multi Switching System Adaptor, External Switch & Factory Pressure Sensor.
If you have any questions feel free to PM me
Modified by TimeRacer at 2:50 AM 11/21/2006
Modified by TimeRacer at 9:11 PM 12/3/2006
Modified by TimeRacer at 4:09 PM 12/6/2006
Modified by TimeRacer at 1:57 AM 12/9/2006
Modified by TimeRacer at 7:51 PM 1/1/2007
Old Nov 18, 2006 | 02:01 PM
TimeRacer's Avatar
Default Re: FS: GReddy E-manage Ultimate & Boomslang PnP Harness (TimeRacer)
bump
Old Nov 19, 2006 | 05:49 AM
TimeRacer's Avatar
Daily bump
Old Nov 20, 2006 | 04:22 PM
TimeRacer's Avatar
bump
Old Nov 22, 2006 | 03:11 PM
TimeRacer's Avatar
bump
Old Nov 22, 2006 | 05:18 PM
FuNkDrSpOt's Avatar
I'm very interested. What are the 2 sensors that you have the PnP harness connected to?
Old Nov 23, 2006 | 06:54 AM
TimeRacer's Avatar
Default Re: FS: GReddy E-manage Ultimate & Boomslang PnP Harness (FuNkDrSpOt)
The 2 sensors are hooked up to the only ones the E-manage has active in this current version. Water temp and air temp. The knock sensor output on the E-manage has not been fully implemented but supposedly will be done though future firmware upgrades that are free from GReddy.
Old Nov 25, 2006 | 08:08 AM
TimeRacer's Avatar
bump
Old Nov 27, 2006 | 04:20 PM
TimeRacer's Avatar
Still for sale
Old Nov 30, 2006 | 02:17 PM
TimeRacer's Avatar
bump
Old Dec 3, 2006 | 08:11 PM
TimeRacer's Avatar
bump
Old Dec 6, 2006 | 03:13 PM
TimeRacer's Avatar
bump
Old Dec 9, 2006 | 12:57 AM
TimeRacer's Avatar
bump
Old Dec 13, 2006 | 07:03 AM
TimeRacer's Avatar
prices reduced
Old Dec 16, 2006 | 05:09 AM
TimeRacer's Avatar
bump
Old Dec 18, 2006 | 11:19 PM
TimeRacer's Avatar
bump
Old Dec 22, 2006 | 03:36 AM
TimeRacer's Avatar
bump
Old Dec 27, 2006 | 03:22 PM
TimeRacer's Avatar
bump
Old Jan 1, 2007 | 06:49 PM
TimeRacer's Avatar
up
Old Jan 11, 2007 | 07:25 PM
TimeRacer's Avatar
bump
jeffk182
Apr 30, 2007 06:04 PM
andyrew500
Aug 20, 2006 08:47 AM
Excelerate
Jan 19, 2006 11:41 AM
