91 si to 88hf dash
Old Nov 17, 2006 | 11:20 PM
CLE's Avatar
CLE
Default 91 si to 88hf dash
I have a wrecked 91 si and a clean 88hf. I bought the hf with the ecu harness all chopped up, they tried to rig their own obd-1 conversion.
I wanna swap out the ugly blue dash with the si's.
Can I switch out the 91 dash harness into the 88 to make it all plug in play/fix the ecu wiring with the 91s or will I run into any problems?
Old Nov 17, 2006 | 11:25 PM
1 Fly SI's Avatar
Default Re: 91 si to 88hf dash (CLE)
You should be able to just make sure you are using the same engine harness that goes with the dash harness.
Old Nov 19, 2006 | 09:50 PM
CLE's Avatar
CLE
Good deal, yeah im using the si engine harness too.
§95HATCH§
Aug 4, 2011 05:18 PM
xkagax
Nov 21, 2006 04:57 AM
AZTEKEF9
Nov 4, 2005 05:13 PM
flatblk
Sep 28, 2005 06:19 AM
