d16y8 problems.. need help
ok.. i got a 97 civic dx.. just put a d16y8 in it ... had to put my 1.5 throttle body on it.. it works. but my car boggs between 2 and 1 grand when it sit and idel for a min than it stops.. why ? next ? is i am getting like 5mpg now.. i put 30 all together since last thursday and im on e again.. why is that sucking gas.. let me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vahonda97 »</TD></TR><TR><TD CLASS="quote">ok.. i got a 97 civic dx.. just put a d16y8 in it ... had to put my 1.5 throttle body on it.. it works. but my car boggs between 2 and 1 grand when it sit and idel for a min than it stops.. why ? next ? is i am getting like 5mpg now.. i put 30 all together since last thursday and im on e again.. why is that sucking gas.. let me know </TD></TR></TABLE>
I don't know much about OBDII motors, but I'll try and point a few things I would definately make sure to check. Are you using the d16y8 ECU? Throwing any CELs? Does your car bog when its cold or it doesn't matter on the temp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vahonda97 »</TD></TR><TR><TD CLASS="quote">i put a ex harness in it so it is already 2 wires.. would the 1.5 throttle body make a diffrence.. </TD></TR></TABLE>
I'm assuming it shouldn't. When I swapped my z6 the TPS sensor was broken and I didn't know how to calibrate a new one so I just took my throttle body off of my dx motor and its always ran fine. No bogs etc. But you know I did remember here on H-T couple guys were having bog issues and it turned out to be there coolant temp sensor
