turn signal
Old Nov 17, 2006 | 06:08 PM
cdizzle's Avatar
Default turn signal
i changed to clear turn signals cus my other stock one busted, and i replaced my turn signal bulb but now my passenger side is not working, i attempted to re-seat the bulb and somewhere in the process it came on but then turned off again quickly now it wont come back on! any help?
Old Nov 17, 2006 | 06:17 PM
cdizzle's Avatar
Default Re: turn signal (cdizzle)
edited! ttt
Old Nov 17, 2006 | 06:21 PM
Eran's Avatar
HT White Ops
What year civic do you have? If you have a 6th gen, you might have bought a 1156 instead of an 1157.
Old Nov 17, 2006 | 10:17 PM
cdizzle's Avatar
93
Old Nov 17, 2006 | 10:32 PM
sasser43's Avatar
shorted out maybe?
check to see if youre getting current with a test light and make sure youre bulb is in good of course
Old Nov 19, 2006 | 07:07 AM
cdizzle's Avatar
k i checked im getting current and the bulb isnt burnt out. the turn signal actually works if my signal is turned on. but otherwise its just off. any ideas?
Old Nov 20, 2006 | 10:25 PM
cdizzle's Avatar
anyone know why my bulb wont work unless my singla is actually on? like your daytime running lights both turn signal bulbs should be on and then fl;ash when u activate a signal? anyone have any ideas? is it just the bulb or is there something else going on
Old Nov 20, 2006 | 10:29 PM
bpr0422's Avatar
Default Re: (cdizzle)
the 93 corners are dual filament bulbs.
even tho the flashing works, the "running" filament might be burnt out or that fuse is burnt out..
its late, so i dunno exactly what fuse but it should be on the interior fuse block under steering column.
MDAMP2005
Oct 31, 2018 06:51 AM
mr poo
Honda Civic (2006 - 2015)
Jun 21, 2018 11:18 AM
sfmalerich
Jun 4, 2017 12:20 PM
TimVanScyoc
Mar 31, 2017 03:22 AM
Acethriller
Lighting
Jan 4, 2014 07:58 PM
