Wheel fitment.
Old Nov 17, 2006 | 05:32 PM
velocity's Avatar
Default Wheel fitment.
Does anyone know if 18x8 would fit my 01 honda accord without any rubbing issues. Thank You
Old Nov 17, 2006 | 06:32 PM
old man neri's Avatar
Default Re: Wheel fitment. (velocity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocity &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if 18x8 would fit my 01 honda accord without any rubbing issues. Thank You</TD></TR></TABLE>
What kind of accord (engine, package, no. of doors.....)
It might, be warned however that if you live in snowy Colorado you will need another set of tires and rims in the winter.
Old Nov 18, 2006 | 08:22 AM
velocity's Avatar
2001 accord coupe v6. i live in colorado but want to order rims, and put them on in the spring. for sure dam snow.
Old Nov 18, 2006 | 08:34 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (velocity)
Rubbing is determined by the tire size, not the wheel size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocity &raquo;</TD></TR><TR><TD CLASS="quote">2001 accord coupe v6.</TD></TR></TABLE>
If it's an LX, the stock tire size is 205/65-15. If it's an EX, it's 205/60-16. Either way, your best tire size for 18" wheels on your car is 215/45-18. This size should not rub, assuming your wheels have the proper offset.
Most 215/45-18 tires are approved for mounting on rims that are 7.0-8.0 inches wide. 18x8 should work, but I would be more inclined to go with the 18x7.5 if it's available in the rims you're considering.
I'm sure you already know that 18" tires are going to be a lot more expensive than the smaller sizes; for example, even the bargain-priced (and excellent) Kumho Ecsta SPT costs almost twice as much as the same tire in most 15" sizes.
Old Nov 19, 2006 | 10:44 PM
vtecsi00's Avatar
Default Re: (nsxtasy)
won't rub as long as you have an offset of 40mm or higher
88Hatchy
Jun 8, 2009 04:55 PM
federal1
Jun 6, 2007 08:18 AM
shibbywhitedude
Jan 13, 2007 11:18 AM
99accordv6
Mar 16, 2004 12:23 PM
greengangsta
Mar 23, 2003 07:31 PM
