Machining OEM Type R flywheel to 11lb?
Old Nov 17, 2006 | 02:46 PM
lowezz's Avatar
New User
Default Machining OEM Type R flywheel to 11lb?
Has anyone here machined their OEM flywheels, and have had no problems? I'm thinking of machining my Type R fly down to 11lb instead of buying a lightend one for mega bucks! Any suggestions? Thnx!
Old Nov 18, 2006 | 01:55 PM
clayne's Avatar
Default Re: Machining OEM Type R flywheel to 11lb? (lowezz)
Bad idea.
Old Nov 20, 2006 | 06:40 AM
b18sihatch's Avatar
im sure it would cost you just as much to get a new flywheel than to do that
Old Nov 20, 2006 | 08:24 AM
rtype11's Avatar
i machined my LS flywheel in 1998 to about 13lbs, still using it today no problems.
Old Nov 20, 2006 | 08:37 AM
Bakeoff's Avatar
my friend is a machinist and has done my D series flywheels down to 10.2lbs or so. A couple of them. They have been great.
He did a couple B series, and got them down to about 12lbs. Go below 12 and it will be really hard to balance. He couldn't get one right at about 10.3lbs and it ended up being a shop hammer. One smack on the pickle fork with that thing, and your ball joint is loose!
Old Nov 20, 2006 | 09:06 AM
b18sihatch's Avatar
Default Re: (Bakeoff)
but the fact that machining it would probably be as much if not more than a aftermarket flywheel, why not just get one already light?
Old Nov 20, 2006 | 11:09 AM
rtype11's Avatar
Default Re: (b18sihatch)
I cant buy an aftermarket flywheel for 50 bucks. plus i never wanted to go to light.
Fnix
Transmission & Drivetrain
Sep 29, 2010 08:37 AM
LaOstha
Mid-Atlantic (Sales)
Jan 25, 2010 03:31 PM
dlaub25
Aug 31, 2008 04:35 AM
G2_Fella
Aug 21, 2008 06:41 PM
IntegR
Apr 26, 2007 01:45 AM
