Engine build update.
Well the engine was assembled today by Gord Bush Performance and I hung around with my camera for the festivities. Here are a few images from the build:
Typical intake port:
Reworked combustion chamber:
Block looking pretty:
3.5lbs off the crank:
Head assembled:
Pro1 cams all nestled in:
Gears installed:
Getting those lumpsticks dialed in:
All buttoned up:
Head assembled:
Gears installed:
All buttoned up:
WOW, that's awesome
. It's funny, I was about to PM you yesterday asking how the engine build was going; and here you are
Does the ATi damper allow you to run the PS?
When is the tune going to happen?
. Does the ATi damper allow you to run the PS?
Dam i wanna see it in person, cant wait and EXPO's not to far away as well... Look pretty all nice and clean and ready to be placed back in its home sweet home of a shell ....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoxtegfoo »</TD></TR><TR><TD CLASS="quote">Simply beautiful. Thanks for posting pics. I learned some new things just by looking at them. Enjoy!</TD></TR></TABLE>
I learned where cam seals go now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">I hate motors.</TD></TR></TABLE>
I think its more an issue of them hating you.
Motor looks awesome Doug. You're car is really going to move now, which it already did before.Great pictures as always too man.
Thanks everyone... to say I am a little pumped right now would be an understatement. Watching the engine go together yesterday was fantastic.
The static compression on the engine was measured to be 11.9 to 1 which is right about where I wanted it to be.
The Cams were dialled in to Skunk2 specs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camlob »</TD></TR><TR><TD CLASS="quote">You mind me asking what pistons are those? How much static cr will it have? </TD></TR></TABLE>
Wiseco Pistons part number: K566M815
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket »</TD></TR><TR><TD CLASS="quote">I learned where cam seals go now .</TD></TR></TABLE>
Sharp eye! That is one of the very first Skunk2 cam seals outside their factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektR »</TD></TR><TR><TD CLASS="quote"> Nice Build! My only gripe would be the Moroso oil pan, mine always leaked and I couldn't ever get it to stop. That was a few years back tho so maybe they've fixed it. </TD></TR></TABLE>
I've been running with this pan for 6 months without any leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">chris - who wants some L glass! </TD></TR></TABLE>
I'll have to let you try some of mine out at the Expo, but only if you be sure to capture some on track shots of me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket »</TD></TR><TR><TD CLASS="quote">...Does the ATi damper allow you to run the PS?
When is the tune going to happen?</TD></TR></TABLE>
Yes there is another pulley that gets mounted to it when you run PS, its included with the damper.
The tune is not likely to happen until the spring time when the car comes out of hibernation.
I didn't realize 3.5 lbs could be shaved off of the crank. And I wasn't familiar with the ATI pulley. I'll have to do some reading up on that.
When I had an Integra RS about 4 years ago, I rebuilt the engine in a class I had, but that was with stock parts and specs. This is the way to really rebuild your motor.
