EJ1 Guage Cluster Help
Old Nov 17, 2006 | 11:47 AM
93allmotorcoupe's Avatar
Default EJ1 Guage Cluster Help
Hi. Recently I decided to remove the ricey indiglo guages that the original of my car had previously installed. Once I took the cluster out, I realized he also removed the lights in the back of the cluster for the tach/speedo/fuel/temp guages. I finally tracked down the sockets I needed but it turns out the bulbs in them were no good. I put new bulbs in them, went to turn the lights on, and still no dice. I also checked the dimmer switch to rule that out. Im getting 12V in and 12V out. So Im assuming the dimmer switch is good, and I should mention that all the other lights in the cluster (CEL, Battery, SRS) work fine, so Im assuming its not a problem with the cluster itself. Do you guys have any input?
Old Nov 17, 2006 | 01:55 PM
Default Re: EJ1 Guage Cluster Help (93allmotorcoupe)
Old Nov 17, 2006 | 02:32 PM
aeboync's Avatar
Just try putting new lights in. You can get some at auto zone. I forget the size, i think its #74 but they should be able to tell you the size or put in LED's. Which you can buy from http://www.superbrightleds.com/mini-wedge.html
Old Nov 17, 2006 | 03:10 PM
Default Re: EJ1 Guage Cluster Help (aeboync)
I did put new lights in. Brand new, out of the box, from auto zone. Still nothing.
Old Nov 17, 2006 | 03:42 PM
aeboync's Avatar
hmmm...do your lights on your climent control turn on? And check your fuses..
Old Nov 17, 2006 | 04:08 PM
Climate control lights have never worked. But all fuses are good, however which one should I be checking specifically? As far as I know, there isnt a specific fuse for the climate control/cluster lights.
Old Nov 17, 2006 | 06:08 PM
aeboync's Avatar
fuse # 19
Old Nov 17, 2006 | 06:44 PM
As I suspected, that fuse is good. And as I said, the other dash/cluster lights are working fine. For some reason its only the cluster lighting
Old Nov 18, 2006 | 04:20 AM
aeboync's Avatar
hmm... I have no clue then. Maybe someone can help...bump for an answer
Old Nov 18, 2006 | 12:04 PM
up
Old Nov 18, 2006 | 06:32 PM
aeboync's Avatar
Do you know anyone with a eg? so you can swap clusters for a min or 2 to see if its actually the car or the actual cluster itself?
Old Nov 19, 2006 | 02:30 PM
polishrifle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeboync &raquo;</TD></TR><TR><TD CLASS="quote">Do you know anyone with a eg? so you can swap clusters for a min or 2 to see if its actually the car or the actual cluster itself?</TD></TR></TABLE>
I could help with that
Old Nov 19, 2006 | 02:34 PM
Default Re: EJ1 Guage Cluster Help (polishrifle)
Thanks for the offer man, unfortunately I just flew home for Thanksgiving yesterday. When I get back Id definitely be up for it though...at least that would rule out whether its the cluster or the dimmer switch. Ill let you know when Im back in West Lafayette
Old Nov 19, 2006 | 04:21 PM
bpr0422's Avatar
how was the indiglo gauges wired up?
he could've cut the wire that provides the 12v signal for the lights.
if your climate lights never worked before, it could be the same problem - somewhere the wire that provides 12v to the dash lights was cut.
does your head unit dim when you turn your lights on? if it doesn't it could be the same problem, or you just didn't hook up that wire...
gl finding that cut wire.
Old Nov 19, 2006 | 08:33 PM
Default Re: EJ1 Guage Cluster Help (bpr0422)
The indiglo guages were wired off their own power source with a seperate dimmer switch, none of the factory wiring was touched. I still speak to the original owner, he didnt cut any wires. And the climate lights dont work either because the bulbs burnt out or he removed them, I know he didnt cut the power wire. I dont have a head unit anymore, but I never had a problem with it while it was in there.
zpayne21
Jan 5, 2015 07:07 PM
worx
Nov 7, 2012 06:10 AM
JDM-ish
Feb 11, 2010 12:47 PM
dravesef
Jun 19, 2008 03:46 PM
ge_ej1
Jan 31, 2008 09:00 AM
