fuel filter!!!!!
Old Nov 17, 2006 | 11:03 AM
redferio's Avatar
Default fuel filter!!!!!
I need to know whats the banjo bolt thread....or just the thread of the stock fuel filter..Thank you all
Old Nov 17, 2006 | 11:13 AM
standbackimapro's Avatar
You want to know what a banjo bolt is? or what.. i dont understand your question
Old Nov 17, 2006 | 11:15 AM
93egsir's Avatar
Default Re: fuel filter!!!!! (redferio)
12x1.25 if you are looking for a metric to an fitting the only one I've found is goodridge.
http://www.partsamerica.com/Pr...set=A
Old Nov 17, 2006 | 02:07 PM
redferio's Avatar
Default Re: fuel filter!!!!! (93egsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsir &raquo;</TD></TR><TR><TD CLASS="quote">12x1.25 if you are looking for a metric to an fitting the only one I've found is goodridge.
thanks..
Old Nov 17, 2006 | 02:23 PM
redferio's Avatar
russell makes banjo fitting.
http://www.jegs.com/webapp/wcs...73_-1
Old Nov 17, 2006 | 02:35 PM
NJcoupe's Avatar
I wouldn't be using -3AN for fuel line.
Old Nov 17, 2006 | 02:50 PM
redferio's Avatar
Default Re: fuel filter!!!!! (dxcoupe.)
why?
Old Nov 17, 2006 | 06:19 PM
NJcoupe's Avatar
PM'd you.
Old Nov 17, 2006 | 06:21 PM
NJcoupe's Avatar
Here is the link to the correct fitting with the hose end style.
http://store.summitracing.com/...w=sku
Old Nov 17, 2006 | 06:29 PM
Luserkid's Avatar
Yea that 3AN is way to small for fuel. 3AN is normally used for something like brake lines or clutch lines, not fuel. You want a min. of 6AN.
Old Nov 17, 2006 | 06:43 PM
NJcoupe's Avatar
Default Re: fuel filter!!!!! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Yea that 3AN is way to small for fuel. 3AN is normally used for something like brake lines or clutch lines, not fuel. You want a min. of 6AN.</TD></TR></TABLE>
Correct
Old Nov 17, 2006 | 07:33 PM
17's Avatar
17
6an minimum
Old Nov 17, 2006 | 10:01 PM
spoonracer84eg's Avatar
Default Re: fuel filter!!!!! (17)
Jagshemash! My name Borat. I like you, I like sex. Its nice!
Old Nov 18, 2006 | 07:27 AM
93egsir's Avatar
I used a metric thread to an adapter to get rid of the banjo fittings then went straight into the end of my aem fuel rail.
Old Nov 18, 2006 | 09:59 PM
redferio's Avatar
thank you all
raidacaipo
Sep 12, 2008 02:31 PM
cueballsi
Apr 26, 2006 11:36 AM
ochsy03
Jul 16, 2005 08:23 AM
LudeChild
Apr 3, 2005 09:54 PM
D-SPEED
Feb 4, 2002 02:03 PM
