stock 91 teg: big bog from idle to around 2500rpm
Old Nov 17, 2006 | 09:50 AM
essex's Avatar
Default stock 91 teg: big bog from idle to around 2500rpm
What do you think could cause a bog or miss from around idle to 2500? The rest of the rpm range is perfect. Just down low it totally misses.
I changed the plugs & wires...also swapped ecu's but still does it.
No codes.
I didn't look at the dis cap or rotor though. But if it was one of those then why would it drive fine the rest or the rev range?
Old Nov 17, 2006 | 02:55 PM
essex's Avatar
Default Re: stock 91 teg: big bog from idle to around 2500rpm (essex)
ANY IDEAS
Old Nov 17, 2006 | 03:25 PM
Fat Chick Magnet's Avatar
maybe timing.
JONESER
Sep 3, 2008 03:32 PM
B16B_coupe
May 29, 2008 09:00 AM
BK101
Oct 12, 2001 05:06 AM
BK101
Jun 21, 2001 01:16 PM
