rebuilt b17a1
i'm going to rebuilt my b17a1 motor, do you guys have any ideas for me.
I want to fully built my motor, what parts are good for this motor.
my idea was itr valvetrain with ctr cams, skunk2 intake manifold with itr t/b.
aem fuel rail. what do you guys think.
I don't know what to do with the block. so any ideas would be great.
I had a b17 in my 92 gsr. I was gonna build it, but decided to just sell it.
I would:
JDM OS B16 pistons
Skunk2 Proseries Camshafts
Adj. Cam Gears
Skunk2 Valvetrain
skunk2/blox/ IM
Skunk2/ITR throttle body
Balance and Micropolish crank
Balance rods
new bearings, gaskets, etc...
and a good tune and you'll have a great motor
I would:
JDM OS B16 pistons
Adj. Cam Gears
Skunk2 Valvetrain
skunk2/blox/ IM
Balance rods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projsectEF »</TD></TR><TR><TD CLASS="quote">damn really? cool dude I didn'y even know that. I'm trying to go n/a and run 12's
what should I do if its possible?</TD></TR></TABLE>
NA to run 12's with a B17 takes alot of work and a hell of a tuner. I would do something along the lines of a good built high reving bottom end... pistons rods etc... as for the top end if you wanna run 12's your gonna need some pretty agressive cams all new valve train... it takes ALOT of work to get your car that quick... Also weight reduction and suspension is key. Make sure you take a **** before you race too....
Chassis setup and $8k in the motor....check out omnimans B16 build up. Follow the same guideline....and then you'll need alot of track time to have the ability to drive it to a 12.
with the setup I described, you will probably be around 180-190whp with a good tune.
run 12's? probably not.. run 13's, maybe with a good driver and good tires, suspension, light rims..
it will definitely be a quick street car and im sure you'll have lots of fun.
I know I do and I have 162whp with a B16.
There are some things I know I some I don't know like what is the difference between whp and hp?
can you explain to me what whp is?
180-190 whp? That doesn't sound too pleasing if I spend hella money on it. How do I make a 250hp car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projsectEF »</TD></TR><TR><TD CLASS="quote">There are some things I know I some I don't know like what is the difference between whp and hp?
can you explain to me what whp is?</TD></TR></TABLE>
whp is wheel horsepower. the actual power being delivered to the wheels. hp is commonly known as chp, hp made at the crank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">180-190 whp? That doesn't sound too pleasing if I spend hella money on it. How do I make a 250hp car?</TD></TR></TABLE>
boost it
boost it
250hp = ~205whp
Also note that many many many 250hp cars do NOT run 12s, thus its unlikely you'll get there with 250hp. Spend $3k for a decent turbo setup and you can make 240-250whp....however most of those setups are slower then NA setups due to the "hill" of a torque curve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood »</TD></TR><TR><TD CLASS="quote">
boost it</TD></TR></TABLE>
2 other choices:
-Sell it and buy a car that actualy has a decent tq/hp ratio
or
-Dump 10k into a NA setup....
2 other choices:
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">250hp = ~205whp
i overlooked that
i overlooked that
landon1405
Aug 9, 2011 12:10 AM
2 litre EG
Feb 8, 2002 12:59 PM
