Will 88 civic fenders fit an 88 crx???
Old Nov 17, 2006 | 06:56 AM
Xemu's Avatar
Default Will 88 civic fenders fit an 88 crx???
Well will they??? Thanks
Old Nov 17, 2006 | 07:23 AM
Duncan90si's Avatar
Default Re: Will 88 civic fenders fit an 88 crx??? (Xemu)
No. they are different.
Old Nov 17, 2006 | 07:28 AM
Deetz's Avatar
Crazy Honda Guy
As mentioned already, no. The whole outside of the body of a crx is different from the civic with the exception of the hood and headlights.
Old Nov 17, 2006 | 10:14 AM
Mugencrxsir1's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">As mentioned already, no. The whole outside of the body of a crx is different from the civic with the exception of the hood and headlights.</TD></TR></TABLE>
Well said, but if you want 88 civic fenders, you will need the 88 civic bumper. I did this because I liked the flare of the civic fenders, but I orders a mugen civic bumper to fit the civic fenders. It will work, you just have to mix and match parts...
Old Nov 17, 2006 | 02:31 PM
Xemu's Avatar
Default Re: (Mugencrxsir1)
So is that all I'd need is the front bumper off a civic?? Or will I need anything else??
Old Nov 17, 2006 | 02:55 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">Well said, but if you want 88 civic fenders, you will need the 88 civic bumper. I did this because I liked the flare of the civic fenders, but I orders a mugen civic bumper to fit the civic fenders. It will work, you just have to mix and match parts... </TD></TR></TABLE>
No it won't you will have to cut and weld the fenders together for the bottom part is different, and won't bolt up. I've posted this atleast 5 or 6 times. Please use the search feature. I've done this swap before don't question me it was from firsthand experience.
Old Nov 17, 2006 | 05:01 PM
Default Re: (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">No it won't you will have to cut and weld the fenders together for the bottom part is different, and won't bolt up. I've posted this atleast 5 or 6 times. Please use the search feature. I've done this swap before don't question me it was from firsthand experience. </TD></TR></TABLE>
Bart i don't know that your talking about, but my crx right know has 88 civic fenders on it and they bolted right up, no welding. So don't go saying I don't know what I'm talking about.......The bumper will line up correctly if the bumper support is not bent, but I do not have a stock civic bumper, i have a fiberglass bumper, but still fits perfectly.
Old Nov 17, 2006 | 05:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xemu &raquo;</TD></TR><TR><TD CLASS="quote">So is that all I'd need is the front bumper off a civic?? Or will I need anything else??</TD></TR></TABLE>
Bottom line, civic fenders with civic bumper will fit the crx. I've done it, and it's a bolt up application, i don't know where you go this welding crap from..........
Old Nov 20, 2006 | 08:51 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">Bottom line, civic fenders with civic bumper will fit the crx. I've done it, and it's a bolt up application, i don't know where you go this welding crap from..........</TD></TR></TABLE>
It isn't a bolt up operation. The lower part of the fender is totally different. The CRX has a lower plastic peice, and the Civic doesn't, and it can't be added to the civic. Now if you are using a body kit to cover it up, that will probally work. With a stock body, and stock sideskirts it won't, wll it might but it will look like crap, w/ that section of the sideskirt missing.
Civic
CRX
DuckEggs
Apr 2, 2009 09:27 AM
civicb16eg
Mar 15, 2009 06:44 PM
stunn'd
Mar 21, 2007 02:24 PM
Honda_ThuGZ
Oct 15, 2006 02:37 PM
dc5mikeydc5
Apr 25, 2006 01:29 PM
