Pic Requests: holset turbo's on ramhorns ot topmounts
Old Nov 17, 2006 | 05:10 AM
RACEPAK's Avatar
Default Pic Requests: holset turbo's on ramhorns or topmounts
sup everyone.
i'm gonna build a manifold for my b16. but i havnt decided yet if i want ramhorn or topmount.
please post some pics of your holset setup's.
single and divided housings.
thanks
Old Nov 17, 2006 | 05:58 AM
drumking15's Avatar
looks no different than anything lese on ramhorn...compressor must be on the drivers side...and youll most likely have to hack up you a/c mount...the turbo is massive!
right now its undivided...but i plan on makin a topmount split scroll mani this winter if the funds allow it
Old Nov 17, 2006 | 08:49 AM
RACEPAK's Avatar
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">looks no different than anything lese on ramhorn...compressor must be on the drivers side...and youll most likely have to hack up you a/c mount...the turbo is massive!
right now its undivided...but i plan on makin a topmount split scroll mani this winter if the funds allow it </TD></TR></TABLE>
thats the point. i havnt decided yet if i want to make a ram or a topmount.
i think a topmount will be my best bet if i want to try and keep the p.s on the stock mount.
ps. will a 1.5mm wall thickness 2" pipes be ok?
thAnks,
Old Nov 17, 2006 | 10:30 AM
drumking15's Avatar
i think 2" is a lil much and going to kill the exh velocity...i think the norm is 1.5" sch 10 or 40....and good luck keepin ps w/ a topmount...that compressor is massive...and its alil aqward...look for gt42 setups for starters...if that can fit...hll this should be easy...and id also recomend running a split scroll mani...itll def help spool a lil bit and make some extra power....
if your tryin to keep ps...id prob go w/ a ramhorn style yet mix-up the runners to get a split scroll like ams's evo mani....
Old Nov 17, 2006 | 04:18 PM
Evile140's Avatar
Depends on which ramhorn, if you are making the manifold and have the turbo you can make anything work.
Here is one I did a while back with an hy35w
Later
Randy
Old Nov 18, 2006 | 05:39 AM
drumking15's Avatar
that min would not keep his powersteerin bracket intact...he could cut it and run it w/ one bolt...but i had problem w/ that so i ditched it all together....and as far as i recall all hy's already had the elbow on the compressor...yours appears to be welded on...prob an hx35 ;-p nice setupo btw....are you using the stock wg&gt;?
Old Nov 18, 2006 | 12:53 PM
Evile140's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">that min would not keep his powersteerin bracket intact...he could cut it and run it w/ one bolt...but i had problem w/ that so i ditched it all together....and as far as i recall all hy's already had the elbow on the compressor...yours appears to be welded on...prob an hx35 ;-p nice setupo btw....are you using the stock wg&gt;?</TD></TR></TABLE>
I wasn't trying to keep the power steering, but I'm sure it was possible. And that is an hy35w..the first gen version did not have the elbow on the outlet. It has the vband holding the turbine side on and a single entry housing. I ran this turbo for years on my old ford 2.3. Made 420at the wheels with it
Later
Randy
Old Nov 18, 2006 | 09:24 PM
model x's Avatar
Default Re: (Evile140)
This is my HY35W(not all HYs have the right angle outlet); In the EF chassis the turbo barely fits; I don't think any off the shelf manifold would work.
Old Nov 19, 2006 | 01:16 AM
anusol's Avatar
B A N N E D
Default Re: (model x)
this is the turbo i have for sale ona topmount.
both my holssets, both for sale
Old Dec 26, 2006 | 01:41 AM
KeyserSoze's Avatar
Hope this helps.
Old Dec 26, 2006 | 03:43 AM
F20Cteg's Avatar
Default Re: (KeyserSoze)
What's up with the taper on the downpipe?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">
Old Dec 26, 2006 | 05:59 AM
KeyserSoze's Avatar
Default Re: (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">What's up with the taper on the downpipe?</TD></TR></TABLE>
4" to 3" reducer. I don't really see the need for a full 4" exhaust on my setup.
beast59
May 4, 2008 04:14 PM
champLSinteg
Nov 13, 2007 02:54 PM
motormike40
Aug 23, 2006 11:58 AM
igo4bmx
Feb 24, 2006 10:25 AM
WishinItWas
Sep 22, 2005 03:53 AM
