Suspension & Brakes Theory, alignment, spring rates....
Strange alignment problem
Old Nov 17, 2006 | 04:46 AM
Sam_J's Avatar
Default Strange alignment problem
Abotu a year and a half ago, somebody hit my car (94 accord) going about 20-25 mph, dented up my drivers side, and bent alot of suspension parts (lca, rear subframe, p/s rack, knuckle assembly tie rod, radius rod) I have since replaced ALL of these parts and a few more, and have gotten an alignment, and done an engine swap (h22 w/lsd), gotten another alignment and the car still hooks to the right when I accelerate. I can't figure it out for the life of me, the car brakes straight, and drives relatively straigh when no gas is applied (still veers slightly to the right)
I am baffled as to what else it could be.
Can any suspension guru give me some ideas?
Thanks!
Old Nov 17, 2006 | 05:51 AM
02 accord's Avatar
Default Re: Strange alignment problem (Sam_J)
Your alignment numbers would help.
Old Nov 17, 2006 | 09:36 AM
PIC Performance's Avatar
Did it bend the wheel? What condition are your tires in, and are the tire pressures correct?
Old Nov 17, 2006 | 04:05 PM
Sam_J's Avatar
Default Re: Strange alignment problem (PIC Performance)
Unfortunatly I wasn't given the numbers, but my tire pressure is correct.
It seems something is shifting, because if i hold the steering wheel straight when im cruising, and then hit the gas, still firmly holding the wheel, the car still veers to the right a little. Im tempted to find a front subframe and replace that as well...
petwhookie
Dec 5, 2011 11:07 AM
CarolinaHonda
Sep 3, 2011 08:41 PM
F22PwrdS2k
Honda S2000
Oct 1, 2008 05:36 AM
boots420
May 9, 2007 08:57 PM
byronl
Jul 22, 2006 05:30 PM
