All Motor B20 Dyno Graph
Old Nov 16, 2006 | 09:54 PM
smileycvc's Avatar
Default All Motor B20 Dyno Graph
This is my new b20 set up. The Blue lines are from the dyno today. The red lines are from my old b20 almost a year ago. I have to buy a new intake mani and throttle body then I should hopefully break 225-230. Enjoy
Old Nov 16, 2006 | 10:02 PM
EK k kay's Avatar
Default Re: All Motor B20 Dyno Graph (smileycvc)
Specs?
Old Nov 16, 2006 | 10:07 PM
dohcVTECeg2's Avatar
Default Re: All Motor B20 Dyno Graph (EK k kay)
wow nice #'s
Old Nov 16, 2006 | 10:19 PM
Archidictus's Avatar
Unceasing Measure
This post is worthless without specifications.
Old Nov 16, 2006 | 11:09 PM
smileycvc's Avatar
Default Re: (Archidictus)
B20B4 block and B16 head
Darton sleeves
84.5mm wiseco pistons 12:1 compression
Eagle rods
ARP head studs and rod bolts
Ported Head
BC spec 4 cams
Golden Eagle cam gears
Password JDM Intake
Omni power valvetrain
Walboro fuel pump
Im running a stock B16 intake manifold and Thottle body so that really restricting my power and mid range torque. New Mani and TB should also help me make power past 7600 RPM
Old Nov 17, 2006 | 12:14 AM
viahiptop's Avatar
is it me or does that look paintshopped? not photoshop but paintshop. nice number either way
Old Nov 17, 2006 | 04:52 AM
b16a4's Avatar
Default Re: All Motor B20 Dyno Graph (viahiptop)
ahhaha
yes it does
Old Nov 17, 2006 | 10:48 PM
smileycvc's Avatar
Default Re: All Motor B20 Dyno Graph (b16a4)
sucks having a trial put on your profile. Yes I highlighted the lines in paintshop because it was hard to get a real clear picture.
Old Feb 8, 2007 | 10:17 AM
teamwasabi'sDC4's Avatar
specs on your motor?
Old Feb 8, 2007 | 10:35 AM
doubledeucehatch's Avatar
Wheres you vtec set at it looks like to me that it should be set at around 5,000 so your HP line will be smoother. nice setup though
Old Feb 8, 2007 | 10:42 AM
smileycvc's Avatar
Default Re: (prelude252)
vtec is set about 5600. I thought you move vtec up to keep it from causing a loss in power? The specs are like 2 post above yours.
Old Feb 8, 2007 | 11:19 AM
importsautomotive's Avatar
what type of dyno is that
Old Feb 8, 2007 | 12:15 PM
doood's Avatar
been there done that
Default Re: (smileycvc)
what header and exhaust? with those cams and a better breathing setup you can get more power.
Old Feb 8, 2007 | 12:31 PM
sal's Avatar
sal
Default Re: (doood)
Wow, nice gains. What was your previous setup?
Old Feb 8, 2007 | 12:35 PM
MildWater's Avatar
damn nice b20
Old Feb 8, 2007 | 01:22 PM
smileycvc's Avatar
Default Re: (MildWater)
This was on a dynojet at Intec racing. I am running an RMF header and a straigh through 2.5 inch exhaust. I have a stock b16 IM and TB thats why I had trouble making more power. I ordered an IM and TB from import builders but its been about 4 months now and i havent recieved them. The head is ported and flows great but without the other parts I just cant get enough air in the head fast enough. My old setup was a b20 with a stock head, and lower compression.
Old Feb 8, 2007 | 01:32 PM
nicko360's Avatar
* B A N N E D *
hey i was thinking about taking my car there in a couple weeks how much did it cost you?
Old Feb 8, 2007 | 01:35 PM
Eran's Avatar
HT White Ops
Default Re: (nicko360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">hey i was thinking about taking my car there in a couple weeks how much did it cost you?</TD></TR></TABLE>
Intec would giggle at your car.
Old Feb 8, 2007 | 05:26 PM
smileycvc's Avatar
Default Re: (Eran)
Well my car was on the dyno for about 8 hours. I had to put in a new fuel pump and injectors during the tune. Tunning at Intec is like 160 an hour. I had my motor and everything put together there so I got a huge hook up on the dyno time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Intec would giggle at your car.</TD></TR></TABLE>
Thats not very nice.
Intec will tune your car if you want. However like I said before it expensive. It is also one of the only places around here you can get a dyno tune and their tunner chis is the ****. Call them up and tell them smiley told you to call and they might hook you up. It doesnt matter if you have a full blown race car or just a few bolt ons they will work on your car. If you dont have a crazy setup you probally wont be on the dyno more than an hour.
Old Feb 8, 2007 | 05:29 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">Thats not very nice.</TD></TR></TABLE>
You haven't seen his car.
Old Feb 8, 2007 | 05:32 PM
smileycvc's Avatar
Default Re: (Eran)
not everyone is ballin. But by chance do you have a link to pic of his car? Intec has a hella mexi rice accord they are doin an h22 turbo swap with. That car was laughed at for a minute then they just went back to work. that thing was horrible tho.
Old Feb 8, 2007 | 05:34 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">not everyone is ballin. But by chance do you have a link to pic of his car? Intec has a hella mexi rice accord they are doin an h22 turbo swap with. That car was laughed at for a minute then they just went back to work. that thing was horrible tho.</TD></TR></TABLE>
Never said they wouldn't work on the car .... just said they'd giggle.
Old Feb 8, 2007 | 05:40 PM
smileycvc's Avatar
Default Re: (Eran)
you should take that car their immediatly and just give them a bag of money.
Nonvtec eg6
49
Dec 1, 2012 04:12 PM
1baddohc
Appearance Build Threads
68
Apr 13, 2012 06:31 AM
egboy94
Oct 19, 2010 07:03 PM
smileycvc
16
Nov 20, 2006 02:26 AM
kahren
Apr 25, 2006 10:14 AM
