H22 head swap on a f23 engine?
Old Nov 16, 2006 | 08:30 PM
DSMtuneR22's Avatar
Default H22 head swap on a f23 engine?
What is needed to be done to swap a H22 head to a f23 engine? Does it need any modifications to bolt up? If anyone can give me a solution it would be appreciated.
-thanks-
Old Nov 17, 2006 | 05:54 AM
Andryzzle's Avatar
Default Re: H22 head swap on a f23 engine? (DSMtuneR22)
https://honda-tech.com/zerothread?id=1069869
strait from the Accord FAQ section.. look around a little before you ask something.
Old Nov 17, 2006 | 09:40 AM
DSMtuneR22's Avatar
ok thanks i need to get more familiar with the site
Old Nov 17, 2006 | 02:48 PM
mkinpwrat12g's's Avatar
its a direct bolt up im pretty sure, pm sneezincd5, hes building that motor right now.
Old Nov 17, 2006 | 05:36 PM
future62
Guest
Posts: n/a
Default Re: H22 head swap on a f23 engine? (mkinpwrat12g's)
Bye bye bearings
Old Nov 17, 2006 | 10:44 PM
DSMtuneR22's Avatar
i just thought about somthing the h22a was designed with a open and closed deck design. i believe the open deck was on the newer h22a and the older motor had the closed deck. the open deck design led to warped cylinders, however im guessing i will have to find out if my motor is an open or closed deck depending on what yr h22a head i get correct?
Andyspeciale
Aug 21, 2015 08:35 PM
all_motorsi
Feb 18, 2010 04:01 AM
uneed8
Feb 25, 2009 05:17 PM
SiRTifiedacc
Jul 27, 2006 07:38 PM
Jynxeh
Feb 9, 2006 10:29 AM
