Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Just installed my Corsport Shift Cable Bushings
Old Nov 16, 2006 | 07:34 PM
spoonlongblock's Avatar
Default Just installed my Corsport Shift Cable Bushings
What a pain to install, the cotter pins were a bitch to take out and then when I was installing the bushings I had to sand them down some. Otherwise it was a good upgrade. It really make the the shifts firmer and more precise. With all three shifter upgrades ( see signature) I believe it is a good all around package that takes away unneeded movement and makes the shift throw more precise and shorter.
Old Nov 16, 2006 | 07:45 PM
eL's Avatar
eL
Just for reference... would all 3 of those upgrades work on the FG1?
I know the Comptech SS does.
Must feel really nice after all that
Old Nov 17, 2006 | 05:52 AM
Default Re: (eL)
I don't know to be truthful with you you may have to contact the manufactuer
Old Nov 17, 2006 | 08:55 AM
Demonis's Avatar
I'm not really a fan of short shifters... my friend has one in his 00 si, and i cant tell when i am, and am not in gear...
Old Nov 17, 2006 | 09:01 AM
Hellzcivic's Avatar
Default Re: Just installed my Corsport Shift Cable Bushings (spoonlongblock)
Hi Spoon,
Congrats on the install.
I am not real familiar with the workings of Honda linkage. I know what the short shifter does, I installed one in my car and love it.
What do the other upgrades do? Could describe for me, briefly?
Thanks
Old Nov 17, 2006 | 04:13 PM
COMplex.'s Avatar
Default Re: (Demonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">I'm not really a fan of short shifters... my friend has one in his 00 si, and i cant tell when i am, and am not in gear... </TD></TR></TABLE>
Not an issue with the FG2...
Old Nov 17, 2006 | 05:17 PM
Default Re: Just installed my Corsport Shift Cable Bushings (Hellzcivic)
The shift base bushing basically sharpen the slop in the shifter assy itself so it doesn't move as much. They are aluminum bushings were as the stock as rubber. The shift cable bushings give the shifter a more solid feel and take away the slop that will accur ovewr time with a factory rubber bushing
Old Nov 19, 2006 | 01:02 AM
newdanger's Avatar
I just got my Corsport bushings in the mail and this is what i got:
are these the cotter pins that should be coming with the kit? do they fit, cause they look alot bigger than the stock cotter pins? also what am I suppose to do with the two far right pieces in the picture? I have looked @ a DIY, but it did not specify what to do with the far right pieces in the picture. All help would be appreciated cause I really want to put these babies on.
Also, I heard that the bushings produce premature wear on the tranny cable --&gt; truth or myth?
thanks in advance
Old Nov 19, 2006 | 05:44 AM
Default Re: Just installed my Corsport Shift Cable Bushings (newdanger)
yes the cotter pins will fit and the far right parts are called e clips when you get the bushing all the way thru the cable end you will have enough room to press that clip into the slot of the bushing and make it secure
Old Nov 19, 2006 | 06:58 AM
Caveman74's Avatar
There is not enough room for the cotter pin to fit through. I had to just use one slot on mine. Its not bad for 30.00
Old Nov 19, 2006 | 08:02 AM
Toxis's Avatar
I got both pins on mine to work. Personally, the Corsport bushings are one upgrade I wish I would've not done. Problem is, once they're in, they ain't coming out!! Love my SS though.
Old Nov 19, 2006 | 12:57 PM
Default Re: Just installed my Corsport Shift Cable Bushings (Caveman74)
yeah my pins went all the way thru
Old Nov 19, 2006 | 06:18 PM
newdanger's Avatar
thanks alot. i'll install them tomorrow. i'll let you guys know if i encounter any problems.
did you guys here anything about premature wear on the tranny cable with the installation of the bushings --&gt; truth or myth?
Old Nov 24, 2006 | 04:28 AM
sidewalkserfer's Avatar
I know twm performance makes a ss and bushings for the non-si... but be carefully taking off the blue cap..... it's easy to break and or lose. Plus the bushings are a pain in the *** to put on, drop one.... might as well take out your entire center console.... which is easier than reaching into the shifter assembly to get it out.
TWM Performance
Performance
Dec 27, 2011 10:06 AM
SacrificeTheory
11
Jan 7, 2008 07:09 AM
cbstd
Feb 15, 2007 03:31 PM
GreenBean
Aug 13, 2003 11:18 PM
Sracer125
Jul 17, 2002 09:28 PM
