92 teg dizzy
I need a distributor... but i cant find a half way decent deal on one... except the all promising ebay... but idk if i trust ebay to ignite my fire... any suggestions
the teg is obd-1 (92)
why do you need the whole distributor? the coil and ignition module are replaceable, if that is your problem....only time i can see you needing a whole distributor is if you have a done a swap and need it for OBD-whatever or if the bearing is/has taken a ****
MetalKill
Feb 25, 2003 08:12 PM
