CAT for a JDM 2.5" ITR header or use an emulator
Old Nov 16, 2006 | 05:39 PM
schumi's Avatar
Default CAT for a JDM 2.5" ITR header or use an emulator
What's my best bet for passing the emissions? Current CAT doesn't have the bung for the secondary sensor and Check engine light is ON.
Replace the current CAT with some aftermarklet ones ?(which is connected to a 2.5" JDM ITR header) Which aftermarket CAT?
OR
Continue with the current CAT and use some emulator ( not sure what the hell that is...read here about the emulator)
thanks guys
Old Nov 16, 2006 | 06:00 PM
Padawan's Avatar
Darth ModerVader
Default Re: CAT for a JDM 2.5" ITR header or use an emulator (schumi)
What cat are you using that doesn't have a secondary O2 bung? If the cat itself is functioning and capable of passing emissions testing, just weld in an O2 bung and install the sensor.
Old Nov 16, 2006 | 08:05 PM
schumi's Avatar
Default Re: CAT for a JDM 2.5" ITR header or use an emulator (Padawan)
I got te header and cat used from some one. The CAT is some sort of OEM (Civic or Integra) with 2.5" flange welded so that header is attached. No holes for putting the secondary O2 sensor.
Old Nov 17, 2006 | 04:52 AM
Padawan's Avatar
Darth ModerVader
Like I stated, if the cat works properly and everything bolts together, just weld in an O2 bung and install the sensor.
Old Nov 17, 2006 | 10:01 PM
schumi's Avatar
I guess, I need to somehow pull out the O2 bung from the OEm CAT ( which is of no use now) and weld it onto the CAT on the car now? and then put the O2 sensor back ? thanks
Old Nov 18, 2006 | 05:47 AM
Padawan's Avatar
Darth ModerVader
It would be easier to simply buy a new bung. They aren't very difficult to find.
Old Nov 18, 2006 | 07:19 AM
schumi's Avatar
you mean buy used from some one? or do you get it new?
Old Nov 18, 2006 | 07:58 AM
Padawan's Avatar
Darth ModerVader
New. Among other places, http://kteller.com sells them.
Old Nov 19, 2006 | 05:43 PM
schumi's Avatar
Thanks...Let me ask you this. If you have the CEL ON, is it necessary that you will fail emissions? I heard some place that because of CEL you are running rich?
btw the CAT I have currently is an OEM looking CAT. with 2.5" flange welded to the end. With an OEM CAT, I guess I have more chances of passing emissions?
Old Nov 19, 2006 | 08:18 PM
95 integra's Avatar
Where are you located? If its in cali, then chances are you are going to fail. If you're in TN, then as long as you dont have a CEL and you have a cat, you're pretty much golden.
Old Nov 19, 2006 | 08:32 PM
ac_attak's Avatar
Just take it to an exhaust shop and have them weld in an o2 sensor bung. They will have the part and it shouldnt cost you very much.
Old Nov 22, 2006 | 11:22 AM
schumi's Avatar
Default Re: CAT for a JDM 2.5" ITR header or use an emulator (ac_attak)
O2 sensor bung + Used O2 sensor - $20
Welding the O2 senor bung to the CAT - $20
Passing emissions - Price less!!!!!!!!!!!!!! (Hopefully)
I went to emissions and the guy said your "OBD computer is Not ready for testing".
He asked me to drive around for a day or two and come back for testing. Let's wait and see.
Old Nov 22, 2006 | 12:25 PM
DC4 me's Avatar
if youre in cali, you need to run your oem cat. High flow cats are illegal in cali. And if you have a check engine light on, its automatic failure. Smogging is a bitch in cali
Old Nov 22, 2006 | 12:30 PM
DC4 me's Avatar
typesguy
Feb 23, 2004 11:09 AM
hatch96
Oct 12, 2003 05:37 PM
Etylorcen
Jun 12, 2002 09:17 PM
FusionITR
Mar 28, 2002 10:30 AM
PolySquared
Dec 25, 2001 09:53 AM
