15x7.5 +38mm wheel on a 92 hatch?
Old Nov 16, 2006 | 05:23 PM
Jeanious's Avatar
Default 15x7.5 +38mm wheel on a 92 hatch?
Hi I have searched and googled , but I have came out with nothing. Basically what I am trying to do is fit 15x7.5 +38 offset on a 92 hatch. My questions are, if anyone has used these before and if any major modificatons were made? Any help is greatly appreciated.
Old Nov 16, 2006 | 08:01 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 15x7.5 +38mm wheel on a 92 hatch? (Jeanious)
Don't do it. For a 15" wheel, your car needs 195/50-15 size tires. That size is usually only approved for wheels that are 5.5-7.0 inches wide.
Old Nov 16, 2006 | 10:00 PM
hybrid1224's Avatar
Default Re: 15x7.5 +38mm wheel on a 92 hatch? (nsxtasy)
what's wrong with using a 205/50/15? They can go on up to 7.5" rim.
Old Nov 17, 2006 | 06:01 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 15x7.5 +38mm wheel on a 92 hatch? (hybrid1224)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1224 &raquo;</TD></TR><TR><TD CLASS="quote">what's wrong with using a 205/50/15?</TD></TR></TABLE>
It's the wrong size for the car. It will throw off the speedometer and odometer, and it will result in slower acceleration. There is no significant difference in performance. They are also more expensive than 195/50-15.
If you are looking for better performance, buy better tires, not wider tires.
Old Nov 17, 2006 | 09:49 AM
hybrid1224's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
True, but is 1/2" overall diameter gonna throw everything off enough to worry about it?
Modified by hybrid1224 at 6:38 PM 11/17/2006
Old Nov 19, 2006 | 11:53 PM
vtecsi00's Avatar
yes it will throw your speedo off by only by a mile or two at diferent speeds and you odometer as well
Old Nov 21, 2006 | 07:50 PM
squareback's Avatar
Default Re: 15x7.5 +38mm wheel on a 92 hatch? (vtecsi00)
Enough to worry about? No. Go for it.
What kind of wheel is it? There aren't very many 15" wheels in that width.
Mike
Old Nov 21, 2006 | 09:16 PM
vtecsi00's Avatar
Default Re: 15x7.5 +38mm wheel on a 92 hatch? (squareback)
take a tape measure and measure from your hub to your shocks 5.75 inches. then from your hub measure 2.75 from your hub to the fender and see what clearance you have. if everything works out then put a tire on it that you want and call it a day
Old Nov 21, 2006 | 10:49 PM
Jeanious's Avatar
The tires I was planning on using were 195/50 so they can be a little stretched out on the rim. I am using these wheels for the looks more than performance. I have HX's for some performance.
Old Nov 22, 2006 | 10:34 PM
squareback's Avatar
If these wheels with the 195 tires wil be mostly for looks, do you LIKE the look of tires that are too small for your wheels?
Mike
Old Nov 29, 2006 | 12:18 PM
blksir2's Avatar
i dont think is a bad idea if you are doing some road racing at the track..just make sure you roll the fenders ,get a h&r full spacer with bolts and studs and put 215/50/15 and go road race man!!!!! dont believe me take a trip to your nearest track and see what the pro are using(nasa,scca,or any other events)
Old Dec 1, 2006 | 02:25 PM
Jeanious's Avatar
Default Re: 15x7.5 +38mm wheel on a 92 hatch? (blksir2)
Do you think if I use tires 195/50 stretched it will rub on the inside. I noticed that the rim is about 1cm away from that part that connects the hub to the upper control arm. I want to roll my fenders enough to make it look similar to an old school AE86. I just like that look.
plsarestupid
Feb 12, 2010 01:43 PM
H22Stew
Mar 8, 2008 06:52 PM
Wazup
Jan 3, 2008 09:50 AM
yaoming315
Jun 3, 2007 03:39 PM
jmayhew
May 16, 2005 06:34 AM
