Suspension & Brakes Theory, alignment, spring rates....
would the jdm itr front sway bar fit in my ls
Old Nov 16, 2006 | 05:06 PM
94IntegraLs04's Avatar
Default would the jdm itr front sway bar fit in my ls
i wanna buy an jdm itr front sway bar would tht fit an would i need anything else or is it just bolt on
Old Nov 16, 2006 | 05:41 PM
BlueIntegraBoy's Avatar
Default Re: would the jdm itr front sway bar fit in my ls (94IntegraLs04)
It will fit, you will need the 25mm bushings and ITR front endlinks.
Old Nov 19, 2006 | 06:34 PM
Default Re: would the jdm itr front sway bar fit in my ls (BlueIntegraBoy)
is tht it i dont need no kits or anything else
Old Nov 20, 2006 | 12:33 PM
94eg!'s Avatar
#1 Super Guy
Loved
Out of curiosity, why do you want a larger front sway-bar? Are you trying to reduce the amount of "oversteer" in the LS?
PS: Yes it will fit. As stated, you only need the 25mm mount bushings, and GSR/ITR end-links..
Old Nov 20, 2006 | 04:22 PM
Default Re: would the jdm itr front sway bar fit in my ls (94eg!)
well i have the jdm rear one already i want to make the front one match the rear one at least u know pluz i am doin autox
Old Nov 21, 2006 | 07:50 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94IntegraLs04 &raquo;</TD></TR><TR><TD CLASS="quote"> i want to make the front one match the rear one</TD></TR></TABLE>
It doesn't really work like that. You shouldn't mess with your sway-bars until you know you have a problem with your setup on the track. Your only wasting your money. Yes it will fit, and yes you should wait to see if your getting too much oversteer while Auto-X'ing. I seriously doubt you will have any problems with your current setup. It may even be better without the oversized front bar. The larger front bar will promote understeer, and you probably don't want that...
Old Nov 21, 2006 | 03:48 PM
yea ur right i should wait i just want to know thnx
b18c1vtecdc2
Suspension & Brakes
Oct 8, 2009 09:35 AM
Boots
Suspension & Brakes
Dec 4, 2006 07:36 AM
alwaysoverkill
Suspension & Brakes
Feb 12, 2006 08:14 PM
B18Redline
Jun 26, 2004 10:41 PM
WhitEdRift
Apr 14, 2003 11:11 PM
