Question on b16 swap
Im doin a simple b16 swap into my 91 crx. My question is, do i use the wire harness that came on the b16, or do i take the one off of the old d16 and put it on the b? i have searched. The reason im asking is because i get a diffrent answer from 2 sources.
alright... thanks coot_er for the input.
I know there are a bunch of writeups on the b16 swap. But i havent really found anything that goes into detail on the harness. i guess i should check other sources.
If your CRX is an HF or an SI use the car's harness not the B16's. Also either make a subharness to add VTEC solenoid, pressure switch, 2nd Oxygen sensor, and knock sensor or buy one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">If your CRX is an HF or an SI use the car's harness not the B16's. Also either make a subharness to add VTEC solenoid, pressure switch, 2nd Oxygen sensor, and knock sensor or buy one.</TD></TR></TABLE>
You can also use the dx harness. Just have to convert it to multi point.
CRX A4
46
Mar 23, 2003 06:58 AM
