2 piston caliper vs stock
Old Nov 16, 2006 | 01:53 PM
vlude99's Avatar
Default 2 piston caliper vs stock
So I saved up enough money to get a set of NSX calipers for my prelude. Now that I can afford it, I'm just wondering if there is really a good advantage to get the 2 piston instead of the 1 piston. Do they make much of a difference at all or are they more cosmetic?
edit: I go autoX and mountain driving so I been looking into a better braking system. I already put on stainless steel lines which I think are great.
Old Nov 16, 2006 | 11:34 PM
vlude99's Avatar
seriously? nobody know anything?
Old Nov 17, 2006 | 06:15 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (vlude99)
This is the Wheel and Tire Forum. There is no brake forum; for questions on brakes for your Prelude, ask in the Prelude forum...
(...and no, the difference between the two setups is really minimal. If you're looking for braking performance, just get better pads and fluid. The next significant step up after that is a setup with bigger calipers, bigger rotors, bigger pads and more swept area, although it's pricey and typically requires bigger wheels, too.)
Old Nov 17, 2006 | 10:39 AM
Mike_C's Avatar
pads and fluid are all you need. put your money in the bank
Old Nov 17, 2006 | 07:07 PM
waddy41's Avatar
nsx calipers are workin very nicely on my teggy...i stop real well
Old Nov 18, 2006 | 04:31 AM
Mike_C's Avatar
Default Re: (waddy41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waddy41 &raquo;</TD></TR><TR><TD CLASS="quote">nsx calipers are workin very nicely on my teggy...i stop real well </TD></TR></TABLE>
you'd stop just as well with stock brakes, good pads, and good fluid.
Old Nov 22, 2006 | 08:19 AM
Mike_C's Avatar
i haven't touched my s2000 (it doesn't break), but i do believe it is a single piston.
Old Nov 22, 2006 | 09:28 AM
old man neri's Avatar
I, of course, would concentrate on getting good tires first. Seeing as this is the wheel and tire forum would you perhaps like some assistance in selecting the best tire for your specific needs?
Old Nov 22, 2006 | 10:57 AM
Default Re: (blackdc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc5 &raquo;</TD></TR><TR><TD CLASS="quote">
Talking to me?
Actually you and/or the OP.
eg9_fann
Mar 5, 2011 08:40 PM
crj_lll
Dec 26, 2005 05:22 PM
ShowSpeed
May 27, 2002 11:39 PM
