Best ECU to use with OBD1 ZC if JDM ZC ECU not available.
Old Nov 16, 2006 | 01:41 PM
Castanza's Avatar
Default Best ECU to use with OBD1 ZC if JDM ZC ECU not available.
Did jdm OBD1 ZC swap in civic and still using SOHC ECU. What is the best option if i cant get ZC ECU
Old Nov 19, 2006 | 11:42 AM
Autoworks's Avatar
Default Re: Best ECU to use with OBD1 ZC if JDM ZC ECU not available. (Castanza)
an LS ECU will actually work. Get an ECU socketed and load a stock ZC map.
Old Nov 21, 2006 | 01:17 PM
Castanza's Avatar
Default Re: Best ECU to use with OBD1 ZC if JDM ZC ECU not available. (Autoworks)
Aight thats what i heard just wanted to make sure
thanks greg
Old Nov 21, 2006 | 04:09 PM
KraziCivicSi's Avatar
fool! i told you the EXACT SAME THING!
you doubtin my knowledge???
just kiddin...
Old Nov 22, 2006 | 03:27 PM
Castanza's Avatar
Default Re: Best ECU to use with OBD1 ZC if JDM ZC ECU not available. (KraziCivicSi)
hey just had to make sure...You never know there might have been a better option out there you didnt know about
BoostinZc93
Oct 29, 2006 06:00 PM
ZC CivicJdm
Jun 15, 2006 12:14 PM
. M i c h a e l
Mar 25, 2006 02:59 PM
hondahybrids
Oct 13, 2003 10:06 AM
tdc
Jan 28, 2002 05:06 PM
