rebuilding bottom end questions
Old Nov 16, 2006 | 01:40 PM
tmrtwo's Avatar
Default rebuilding bottom end questions
ok i am rebuilding the bottom end of my h23a1. Can u use h22a pistons n rods? Well if anyone knows about this or has any suggestions for a h23a1vtec all motor plz let me know what would be the best setup and what sizes i would need
Old Nov 16, 2006 | 01:52 PM
redtop22's Avatar
Default Re: rebuilding bottom end questions (tmrtwo)
how to: H23VTEC, H23 VTEC, H23/VTEC (search friendly) [Archived]
Old Nov 16, 2006 | 02:46 PM
dreed2300's Avatar
You can use the pistons but, I would have the machine work done on the block after you give the shop the pistons so that they can measure them exactly. The rods are longer, 20 thousandths too long. You can fix this by machining the piston surface down. It wont hurt anything just might lower your compression a little, not even enough to make a diff. I ran into this problem when I built my motor. I ordered billet rods and they sent me billet rods for an h22. My motor is still running strong today.
Old Nov 16, 2006 | 02:58 PM
tmrtwo's Avatar
Default Re: rebuilding bottom end questions (dreed2300)
so i can use h22 pistons ...should i get h23 rods for the pistons then?
Old Nov 16, 2006 | 03:30 PM
preludeguy_92's Avatar
yes keep the h23 block, crank, and rods and just get the h22 pistons.
Old Nov 16, 2006 | 03:58 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreed2300 &raquo;</TD></TR><TR><TD CLASS="quote">. The rods are longer, 20 thousandths too long. You can fix this by machining the piston surface down. It wont hurt anything just might lower your compression a little, not even enough to make a diff. I ran into this problem when I built my motor. I ordered billet rods and they sent me billet rods for an h22. My motor is still running strong today.</TD></TR></TABLE>
What? BS... an H23 rod is 5.572" long and an H22 is 5.636 Its the compression height of the H22 piston that is .02 more than an H23 which is why they stick out of the hole a bit. (.02" approx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeguy_92 &raquo;</TD></TR><TR><TD CLASS="quote">yes keep the h23 block, crank, and rods and just get the h22 pistons. </TD></TR></TABLE>
kentucky accord
Dec 25, 2008 03:33 AM
xxredpreludesixx
Aug 13, 2005 09:01 AM
ensracer
Mar 3, 2004 06:18 PM
luderone
Nov 6, 2003 09:37 AM
satan_srv
Oct 24, 2002 09:23 PM
