how do i know what size injectors i need?
ok i'm sure there is some kind of math to it but i don't know what measurements i
need. ok i have stock injectors, i get misfire sometimes, i looked at injector 3, the
little plastic piece next to injector head looks cracked. so i checked, oem one is
103 bux, but i see accel injectors in aftermarket books for 79 each, being i don't
want miss matched ones, what should i get?
i see injectors come in many different sizes as far as CC's i'm running NA right
now but eventually am gonna turbo charge, what size do i need? thanks
Buy a set of used stock injectors for $40 or under. Turbo injectors generally ranges from 440s all the way up to 1000+ ccs.
Also, for those who are unaware, you have to have some type of fuel management for larger injectors. Thus, you'll end up spending $500+ just to upgrade injectors.
just stick w/ stock CC.....regardless of OE or aftermarket without major upgrades and tuning larger CC injectors aren't worth it
i got stock injectors from a SOHC civic for my gsr. lol i only paid 20 bucks and i got the fuel rail too. they're all the same pretty much (except for preludes and s2k). 240cc is what you need.
