intake manifold and throttle body?
i got a 98 integra gsr and im looking to get a skunk2 intake manifold and skunk2 throttle body but i dont know what size the manifold is so i dont know if it will fit the throttle body is 68mm do yall think it would fit
What else do you have done to the car? The manifold is a 64mm as I remember and you've really got to have an aggressive setup to make a 68mm TB worthwhile. Generally you're going to lose throttle response and power with a 68mm and generally I dont recommend a 64mm unless you've got cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnasty »</TD></TR><TR><TD CLASS="quote">well i got just mainly bolt ons and maybe going nitrious, what manifold and throttle body do you rec.?</TD></TR></TABLE>
stock
stock
Yea, I'd just roll with the stock one. Stage I cams + higher compression = 62mm, stage II cams and 12ish:1 compression = 64mm and 68+mm is only for BIG all motor setups.
Gordo_eg
Nov 8, 2016 04:32 PM
blackoutvtec845
May 11, 2010 05:49 PM
shahriar35
Jan 31, 2010 12:13 AM
JforJonathan
10
Apr 10, 2004 12:15 PM
