fs- b18b Longblock and y80 tranny, fresh rebuild project
Old Nov 16, 2006 | 06:59 AM
sik_sol's Avatar
B A N N E D
Default fs- b18b Longblock and y80 tranny, fresh rebuild project
hey whats happenin, i've got a 94 LS longblock and tranny ( y80 ). The block has been rehoned, hot tanked, and is all fresh to go. Theres a USDM GSR crank and pistons to go in the block, crank was micropolished and balanced, and I got USDM ITR pistons with pins to go in there too. This will set the compression ratio to around 10.4:1, which is right around where stock b16a is, which the stock injectors, fuel rail can handle just fine. The rail, injectors, wiring harness, and p75 5-speed LS ecu, also come with it, as well as the shift linkage, and drivers side axle (the one that bolts to the block). its just sitting in my entry now, i've run out of time and money so i'm trying to get rid of it as a whole package rather than part it out. I'm located in Maine, but I can get pics out to anyone who wants them. Drop me an email to carbonfiberkeyboard@yahoo.com with HT LS ad in the subject line, or pm me if you have any questions.
I'm not really set on a price, but brand new rings, acl bearings (rod and crank), ARP rod bolts, brand new OEM head gasket.
Again, EVERYTHING, is included in this swap. Head, dizzy, cams, cam gears, valvetrain, valves, rockers, block, oil pan, oil pick up tube, oil baffle, NEW oil pan gasket, NEW Heatguard Intake Manifold gasket, Intake Manifold, throttle body, fuel rail, injectors, stock FPR, usdm ITR pistons, usdm GSR rods & crank, NEW rear main seal, LS oil pump, b18b shift linkage out of 94 integra, drivers side b18b axle, p75 5-speed ecu, obd-1 b18b wiring harness, NEW oem head gasket, AEM power steering pulley on stock pump w/oversized belt, OEM head bolts, ARP 1.6-1.8L rod bolts, y80 5-speed LS transmission w/VSS, and motor mounts...
I may have missed a few things, but upon sale I will do a complete inventory of parts to let anyone know if I missed anything. Best offer takes it, I am totally willing to work something out, its just taking up space now, so the sooner it could go the better.
Well, hope to hear from chall. It's located in Maine zip 04613 for those curious about pick up. I will get exact quotes for shipping before shipping out tho, no sweat.
Old Nov 17, 2006 | 05:03 AM
sik_sol's Avatar
B A N N E D
up
JSPECDC294
Apr 17, 2008 08:49 AM
LPoke
Jan 24, 2008 09:22 PM
h23vtec_dc2
Jun 6, 2005 05:52 PM
Evil P
Mar 25, 2003 12:15 PM
Triple T
Mar 12, 2003 07:56 PM
