Mirror swap
Old Nov 16, 2006 | 06:45 AM
Libertariat's Avatar
Ek Forever y0!
Default Mirror swap
When I bought my car it had some knockoff mirrors on it. They look ok, but I bought some oem ones.
To swap em is there anything I need to know? How do I get started? Just remove the inside cover with snaps?
Old Nov 16, 2006 | 07:05 AM
JDM_teh_WIN!!'s Avatar
Default Re: Mirror swap (ek forever guy)
This is the way I do it.
1.Open door.
2.Remove speaker cover and speaker.
3.Remove bolts around speaker housing.
4.Remove screw holding window button garnish. Remove garnish and unplug connector.
5.Remove screw holding door opener garnish. Remove garnish and unplug connector.
6.Pull on bottom of door panel.
7.Remove the mirror garnish. (in corner by mirror).Unplug connector if you have door tweeters.
8.Remove door panel.
9.You should see 3 nuts holding the mirror on. Depending on what type of mirrors are there now it could be screws. Also if the mirrors are power unplug the connector.
10.Loosen the nuts or screw till you feel the mirror start to seperate from the door. Hold on to the mirror and remove the nuts/screws.
11.The mirrors should come off with a little help.
12.Install the OEM mirrors and reassemble everything.
Good luck.
Tools needed:
Phillips screw driver
8mm or 10mm socket wrench.
Old Nov 16, 2006 | 07:08 AM
Ek Forever y0!
Default Re: Mirror swap (JDM_teh_WIN!!)
I have to take off the whole door panel? FTL
Old Nov 16, 2006 | 07:15 AM
Well you can try to just remove the mirror garnish, but It will be more frustrating. It takes like 15 min to do.
Old Nov 16, 2006 | 07:17 AM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">Well you can try to just remove the mirror garnish, but It will be more frustrating. It takes like 15 min to do.</TD></TR></TABLE>
How so more frustrating? The mirror doesnt look like it connects to anything as far down into the door panel.
Old Nov 16, 2006 | 07:23 AM
Yeah but its a bitch to get the mirror garnish off and back on with out loosening up the door panel.
Trust me I just put my OEM mirrors back on my 96 Civic.
Old Nov 16, 2006 | 07:52 AM
Ek Forever y0!
it's going to have to wait at least a few days anyway. I f'ed up my arm fighting last night. I think I either pulled a muscle or tennis elbow is settling in.
GriFFIthS
Honda Civic (2001 - 2005)
Jul 29, 2008 08:19 AM
ella94
May 16, 2006 10:57 AM
slvrcivic97
Jan 21, 2004 08:50 PM
JDMy0
Aug 24, 2003 01:00 PM
-Gambit-
Aug 26, 2002 09:26 PM
