Removing black stripe from paint
Old Nov 16, 2006 | 06:38 AM
Jedimiah's Avatar
Default Removing black stripe from paint
So i got really lucky and found a fender that matched the color of my car perfectly. My fender was smashed in an accident and I put one on that wasn't painted. However, there is a black stripe (that I think most accords have) running from the back to the front on the fender I bought. My accord has a grey stripe. Yikes, that will look wierd!
So how do you remove that stripe? It feels like a sticker but it wont peel of but a little at a time. I also don't want to ruin the paint. Also, does anyone know where I can get the grey stripe to match my car?
Any help appreciated, thanks.
-1999 Honda Accord LX
Old Nov 16, 2006 | 07:10 AM
knightrider96's Avatar
Default Re: Removing black stripe from paint (Jedimiah)
you can use a heat gun, to heat up the pin stripe, in order for the glue that is holding it to get softer, then use a razor blade to remove, then use any type of adhesive remover to clean any remaining glue on the car.
your best bet to find that pinstripe that you need is either at your local junkyard if you want it cheap or your local honda dealer which will cost you a pretty penny.
Old Nov 16, 2006 | 07:18 AM
Jedimiah's Avatar
Awesone, thanks!
Old Nov 16, 2006 | 07:28 AM
standbackimapro's Avatar
Heat gun... or u can get a pin stripe removal tool,
OR
You can do it very carefully and peel it slowly in a straight line, and itll come off... i just took both sides of a pin stripe with my hands off an accord the other day, took me 10 minutes..
Old Nov 16, 2006 | 09:01 AM
Jonzey94's Avatar
Default Re: (standbackimapro)
not to dis your ideas the easiest and safest way is adhesive remover at carquest...we got the stuff a work and it works great and helps prevent scratching the paint.....heat gun will work to but run into possibly scrtchin the paint....
Old Nov 16, 2006 | 09:29 AM
Jedimiah's Avatar
Default Re: (Jonzey94)
what's the name of the remover?
Old Nov 16, 2006 | 11:47 AM
iam7head's Avatar
Default Re: (Jedimiah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jedimiah &raquo;</TD></TR><TR><TD CLASS="quote">what's the name of the remover?</TD></TR></TABLE>
goo gone, in your homedepot paint area.
some time the pinstripe is clearcoated with the car, if you can't get it loose after a while it usually is.
jefflikesbagels
Paint and Body
Mar 23, 2009 08:13 PM
EtaK
Aug 6, 2004 05:22 PM
therealitsjustme
Jun 4, 2004 04:56 PM
EM1Guru
Nov 29, 2003 02:42 PM
97 CIVIC EX
Nov 7, 2001 08:36 PM
