Vafc 2, is it enough? Please help asap
Old Nov 15, 2006 | 08:23 PM
Prudz_lude's Avatar
Default Vafc 2, is it enough? Please help asap
Can you tune cam gears with a vafc2 or does that even matter.
Old Nov 15, 2006 | 08:31 PM
Silver Surfer's Avatar
Default Re: Vafc 2, is it enough? Please help asap (Prudz_lude)
um a cam gear is not a mod......it is a tuning tool in itself.....you don't tune them....you use them to tune and adjust timing
vafc....vtec/air/fuel controller
Old Nov 16, 2006 | 01:45 AM
redtop22's Avatar
Is VAFC enough for what?
What modifications do you have that require you to adjust the timing?
Do some research on what the VAFC is capable of, and what it is not.
It is NOT capable of tuning cam gears.
Old Nov 16, 2006 | 05:47 AM
ludecz's Avatar
To "tune'' adjustable cam gears you only need to have your car on the dyno and try advancing or retarding one cam 1or 2 degrees at a time. And see if your power/ torque are improving. Basically if you skimm your head you should start with advancing.
Old Nov 16, 2006 | 01:41 PM
Chuckles99SH's Avatar
Unless its a Swiss-army-Vafc2 w/ allen wrenches or hex tools then your **** up creek... If your asking if the Vafc2 can control timing, I dont think so V=Vtec A=Air F=Fuel C=Controler.
Old Nov 19, 2006 | 01:41 PM
Prudz_lude's Avatar
Default Re: Vafc 2, is it enough? Please help asap (Chuckles99SH)
oops. that is what i thought. Just making sure im still a noob
Crx_Civic
Feb 9, 2008 10:19 AM
thetrevdog23
Jun 2, 2007 08:53 AM
EK4 hatchback
Jun 21, 2002 08:40 AM
TypeR509
Sep 26, 2001 06:04 PM
