Steering wheel turns by itself???
Old Nov 15, 2006 | 07:53 PM
BoltonGSR's Avatar
Default Steering wheel turns by itself???
I have a 92 acura legend and whenever i park on uneven ground the steering wheel turns all by itself... then when i go to pull out i hear a loud pop. Im assuming its the cv joints? But could they really make the wheel turn like that??
Old Nov 16, 2006 | 06:29 AM
BoltonGSR's Avatar
bump
Old Nov 16, 2006 | 09:07 AM
ckyguy's Avatar
probably not cv joints
more likely tie rod ends and/or bad alignment
Old Nov 16, 2006 | 09:23 AM
BoltonGSR's Avatar
Default Re: (ckyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckyguy &raquo;</TD></TR><TR><TD CLASS="quote">probably not cv joints
more likely tie rod ends and/or bad alignment</TD></TR></TABLE>My instructor at school said it may be the rack... hmmm... anyone agree with that?
Old Nov 17, 2006 | 09:29 AM
BoltonGSR's Avatar
Default Re: (BoltonGSR)
bump?
Old Nov 18, 2006 | 11:42 PM
Qfactor's Avatar
Default Re: Steering wheel turns by itself??? (BoltonGSR)
maybe you got the new system as Lexus, that selfs park.
Old Nov 19, 2006 | 01:09 AM
BoostedJeff's Avatar
Default Re: Steering wheel turns by itself??? (Qfactor)
who ya gonna call, ghostbusters
Old Nov 19, 2006 | 09:27 AM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor &raquo;</TD></TR><TR><TD CLASS="quote">maybe you got the new system as Lexus, that selfs park. </TD></TR></TABLE>Haha, i was thinkin the exact same thing when i saw it happen. Anyone else have any suggestions? Serious ones?
Old Nov 19, 2006 | 10:50 AM
BoltonGSR's Avatar
bump?
Old Nov 19, 2006 | 06:03 PM
BoltonGSR's Avatar
anyone
Old Nov 19, 2006 | 08:57 PM
loudassVTEC's Avatar
Its either the rack and pinion, or the pump is putting out too much pressure. If its not that, then its alignment. If the caster split is way off, then the steering wheel will turn itself one way depending on the caster angle. The '92 legends have a caster adjustment on the radius rods. I'd say have the alignment checked, and if the cross caster is good (below .5 degrees), I'd say think about replacing the rack, and pinion, and possibly the pump. You might have to have a mechanic check it first to narrow it down to one component.
If the vehicle pulls to one side while you are driving, there is a simple test to try. Put the vehicle in neutral, and turn off the engine (just don't turn the key all the way off, or the wheel will lock, and you could get into an accident), and if it stops pulling, the rack, or the pump is bad. If it keeps pulling, its alignment, or maybe the tires (belt separation, buldges, a different tire on one side compared to the other, etc.)
Hope this helps
Old Nov 19, 2006 | 09:55 PM
Default Re: Steering wheel turns by itself??? (loudassVTEC)
wow good info man
Old Nov 19, 2006 | 11:06 PM
vtecsi00's Avatar
Default Re: Steering wheel turns by itself??? (BoostedJeff)
some tire also have bad tendacies to go with the ruts in the road...i was driving one day and came to a stop and i had 1st gen parad's on my car at the time and the steering wheel did a complete 180 on me when i came to a stop....i put my stocks back on the next day and came to the same stop sign at it didn't do it again...
Old Nov 20, 2006 | 08:13 AM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Its either the rack and pinion, or the pump is putting out too much pressure. If its not that, then its alignment. If the caster split is way off, then the steering wheel will turn itself one way depending on the caster angle. The '92 legends have a caster adjustment on the radius rods. I'd say have the alignment checked, and if the cross caster is good (below .5 degrees), I'd say think about replacing the rack, and pinion, and possibly the pump. You might have to have a mechanic check it first to narrow it down to one component.
Hope this helps</TD></TR></TABLE>Thx for your help. This cooberates with all the advice ive had thusfar...
SETI20
12
Nov 5, 2007 02:25 AM
Mikey3000
May 9, 2006 03:58 PM
beyondspexj
Jan 26, 2006 11:12 PM
Xymox007
Oct 17, 2004 07:07 AM
socalep3
Jan 27, 2004 07:57 PM
