Suspension & Brakes Theory, alignment, spring rates....
Need new bushings for UCA, OEM?
Old Nov 15, 2006 | 06:13 PM
invisible's Avatar
Default Need new bushings for UCA, OEM?
my UCA busings are busted on both sides in the front. is getting oem bushings the best way to go? do they need to be pressed in by a machine?
Old Nov 16, 2006 | 07:59 AM
dvp's Avatar
dvp
Default Re: Need new bushings for UCA, OEM? (Battle23)
It might be cheaper to buy the whole arm from someone on here. I don't know if they even sell stock bushings for those arms seperately. Call the stealership.
Old Nov 16, 2006 | 08:21 AM
instructor74's Avatar
Default Re: Need new bushings for UCA, OEM? (dvp)
At least as far as 92-95 go those come with the upper control arm. So unless you replace them with polly bushings you would have to replace the upper arm assy.
Old Nov 16, 2006 | 09:45 AM
invisible's Avatar
Default Re: Need new bushings for UCA, OEM? (instructor74)
is it # 7?
Old Nov 16, 2006 | 09:54 AM
It should be #5 or #6 but I dont see the mounts let me see what I can find. Here it is for the 93 civic it looks like I was wrong you can get just the bushing for it. Check out the link
http://www.hondaautomotivepart...UCKLE
Old Nov 16, 2006 | 09:58 AM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">It should be #5 or #6 but I dont see the mounts let me see what I can find. Here it is for the 93 civic it looks like I was wrong you can get just the bushing for it. Check out the link
http://www.hondaautomotivepart...UCKLE</TD></TR></TABLE>
my car is a 99, which one is it on here http://www.slhondaparts.com/br...UCKLE
Old Nov 16, 2006 | 01:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 &raquo;</TD></TR><TR><TD CLASS="quote">
my car is a 99, which one is it on here http://www.slhondaparts.com/br...UCKLE</TD></TR></TABLE>
Your should be the first 2 part numbers One of each
Surdomute56
Mar 30, 2017 09:30 PM
BlackCivicEX
Suspension & Brakes
29
Jan 24, 2012 10:27 AM
chrisff521
Suspension & Brakes
Feb 9, 2010 10:22 AM
PatrickGSR94
Suspension & Brakes
14
Dec 4, 2008 06:08 AM
1993gsrcivic
Suspension & Brakes
30
Apr 29, 2008 09:55 PM
