FUSE KEEPS BLOWING
Old Nov 15, 2006 | 05:35 PM
code47mastermind's Avatar
Default FUSE KEEPS BLOWING
Hi after installing a stereo into my car, my instrument panel lights no longer go on
the fuse to my instrument panel lighting was blown, now i replaced it and when i turned on my headlights.. it lights up for a moment and immediately goes out and the fuse is blown again
does anyone know what i did to cause this? its not the big of a deal except i cant see how fast i am going at night now
Old Nov 15, 2006 | 05:38 PM
y7turbo's Avatar
Default Re: FUSE KEEPS BLOWING (code47mastermind)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by code47mastermind &raquo;</TD></TR><TR><TD CLASS="quote">Hi after installing a stereo into my car, my instrument panel lights no longer go on
does anyone know what i did to cause this? its not the big of a deal except i cant see how fast i am going at night now</TD></TR></TABLE>
well if it just happened after the radio install then it has to do something with that. take out the stereo harness and double check the wires are in the correct order and that there are no broken wires or shorts. should be very easy to find.
Old Nov 15, 2006 | 05:44 PM
HA0LEFIED's Avatar
ground your stuff better
Old Nov 15, 2006 | 05:47 PM
i figured it out... some reason the wrong fuse was in there....
i bought the same fuse as replacement... but it was wrong
i havent tried the right one yet, but i will in the morning
the thing i dont understand is why it worked up untill installing my stereo
Old Nov 15, 2006 | 05:48 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: (HA0LEFIED)
check the lum wire from you new stereo
Old Nov 15, 2006 | 06:04 PM
stock_honda_coupe's Avatar
Default Re: (DBL)
You probably shorted a power wire to ground when you did the instal
Old Nov 15, 2006 | 06:05 PM
SNYPR2's Avatar
Default Re: (DBL)
yea same thing happened to me after my radio install. the pink/orange wire for illumination of the stock radio would ground,just tape it and you should be good.
maparman
Jun 9, 2013 07:09 AM
byc_cb7
Sep 28, 2009 02:45 PM
reallycooleg
Jul 10, 2005 07:20 AM
jdmeg9
Apr 30, 2005 08:03 AM
GReddy212
Apr 12, 2005 10:56 AM
