Civic body w/ Acura sole
Thinking about swapping B18c in a 98' sedan. Who's been there and done this. Is there anything critical to know(hidden)?
[Modified by 98lagen, 4:11 PM 5/8/2002]
wooo man there has been TONS and TONS written on a simple B18C swap into a Civic, check out http://hybrid.honda-perf.org/ for starters.
ya there has been tons written on that swap. awesome swap to go with in a civic. lightweight car with a powerful motor. anyway that swap should be so easy!! direct bolt in. i know you will have to get new motor mounts for that GSR motor to put it in the civic. i have those motor mounts and will sell them to you if you didn't get them with the motor because i did a swap in my teg to the b16a2 so i needed del sol mounts and couldnt use my teg mounts. might also need to get gsr axles. also if your civic is not a vtech you will have to run new wires from the ecu to run the gsr vtec. check out what those are if you civic didnt already come stock with a vtec. hope some of that helped
mrgta67
Jun 5, 2005 05:38 PM
Bimmerman
Mar 24, 2005 07:07 PM
