ep3 tail lights
does n e one know if the 02-03 ep3 tail lights fit on the 04-05 ep3? if it does is it a perfect fit? im not gonna get n e if its not a perfect fit. any response is aprreciated thank you
To put '02-'03 tail lights on an '04-'05 model, you need the following parts:
Honda Part Number 33304-S30-003 (Socket) --- Quantity 2
Honda Part Number 04321-SH2-307 (Connector) --- Quantity 2 (However, you only need to buy one package from Honda as they come 5 pieces to a package)
Honda Part Number 33303-S30-003 (Bulb) --- Quantity 2
Your brake sockets/bulbs/connectors remain the same.
Your turn signal sockets/bulbs/connectors need to be removed and connected to your reverse wires. They become your new reverse sockets/bulbs/connectors.
The new sockets/bulbs/connectors (listed above) become your new turn signal sockets/bulbs/connectors.
You do not need to cut your wires. You simply have to remove the wires from the old connectors and install the new connectors. Then the new sockets/bulbs will plug in and you're ready to go.
Its not too bad at all.
All u gotta do is take the trun signal bulbs/socket and put them on the original wires for ur reverse lights
And then use the new sockets u pick up from honda and put them on the original wires for the turn signals.
All the rest is a direct swap.
