Suspension & Brakes Theory, alignment, spring rates....
wheel hop with new clutch and tranny
Old Nov 15, 2006 | 11:51 AM
young noob's Avatar
Default wheel hop with new clutch and tranny
hey guys, i just installed a shorter geared tranny, and an exedy stage 1 clutch, when i shift from 1st to 2nd, i used to just get a chirp, now the gearing has given me more power caz of the gearing, but i get wheel hop, what would you all suggest to cure this problem, also its pretty agressive, my cd player skips and im scared of busing an axle
Old Nov 15, 2006 | 12:14 PM
Boomer234's Avatar
what suspension set up do you have?
solid motor mounts will limit wheel hop and a h-brace/traction bar will help also
Old Nov 15, 2006 | 02:44 PM
ckyguy's Avatar
you don't have to go so far as to put solid mounts in (though if you're hardcore you won't mind the craptastic ride), just start with some polyurethane mounts and traction bar like boomer said
Old Nov 15, 2006 | 04:54 PM
young noob's Avatar
Default Re: (ckyguy)
i have omni power coilovers, 1st generation, the track version, sport not street, and skunk front camber aduster, it doesn't really matter but the rear has omni lca's, asr brace and 22 mm rsb, i think i just need to lock up the front a bit, im going to buy korbach frame lock kit, and see where that takes me, but also, does the h-brace for auto-x too, or is it strictly drag
Old Nov 15, 2006 | 05:55 PM
young noob's Avatar
Default Re: (young noob)
any1 know of a write-up for the mounts and the diy for filling them?
Old Nov 16, 2006 | 10:37 AM
young noob's Avatar
bump
Old Nov 16, 2006 | 12:16 PM
EK k kay's Avatar
PM drflickner and ask about the NRG engine torque damper. I am assuming you have a sohc. He sells them for $55-60 and are very easy to install, has adjustible stiffness, and eliminated 90% of my wheel hop (should eliminate all of your wheel hop since you make less power I assume). Unlike solid mounts and poly inserts, the torque damper did not induce interior noises on my car.
https://honda-tech.com/zerothread/1478866
Old Nov 16, 2006 | 01:00 PM
young noob's Avatar
Default Re: (EK k kay)
thanks ill check that out
Blacklabel182
Apr 2, 2007 06:50 PM
JayDMteg
Sep 29, 2006 06:23 AM
soontobeboost
Nov 4, 2005 06:40 PM
EFin' Kyle
Aug 31, 2004 03:09 PM
PSU-TEG
Apr 19, 2002 07:24 AM
