Suspesion
Old Nov 15, 2006 | 10:26 AM
guero2craze's Avatar
Default Suspesion
I want your opinions on wat to get for a smooth ride...shock and spring wise? I want to lower it bout 1.5 inches?
Old Nov 15, 2006 | 12:50 PM
waddy41's Avatar
how much do u want to spend
i want kw variant 3's
Old Nov 15, 2006 | 02:20 PM
TunerN00b's Avatar
Default Re: Suspesion (guero2craze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guero2craze &raquo;</TD></TR><TR><TD CLASS="quote">I want your opinions on wat to get for a smooth ride...shock and spring wise? I want to lower it bout 1.5 inches?</TD></TR></TABLE>
For a smooth ride, you want the stock suspension. Nothing else will be as smooth, because anything else wil have to make compromises.
For a 1.5" drop, just go get some good quality lowering springs and shocks good enough to handle the new height and stiffer rate. You have to go stiffer as you go lower, or you'll bottom out all the time. Stiffer means less smooth ride quality.
The simple answer is Eibach Sportlines and quality shocks.
Old Nov 15, 2006 | 03:55 PM
PrinceAli132's Avatar
Not sure of how much the ITR springs lower the car but that may be a good option.
Ali
Old Nov 15, 2006 | 10:58 PM
calde-da9's Avatar
spoon coilovers.
stocktonhidlude
Dec 17, 2006 07:50 AM
amej8
Suspension & Brakes
May 2, 2006 12:55 PM
amej8
May 2, 2006 11:32 AM
PetroGuyX
Jun 15, 2003 03:20 PM
SLJ
May 3, 2002 05:29 PM
