Will a 90 accord LX Knuckle and Hub fit on a 93EX
I have a 93 EX that needs a lower ball joints and rotors. Can I take the Knuckle and Hubs off a 90 LX and put them on a 93EX. Also, can I do the same with the Spring/Strut assembly. thanks jim
you can swap the spring strust assembly but you cannot do the knuckle b/c of the ABS sensor. the only difference is that the EX knuckle has holes for the ABS sensor to hook up to and the LX one doesn't.
90-91 all models except for SE didn't come with ABS
ABS is only on 92-93 EX/SE and 91 SE
Thanks for the response. So if I do not want to use the ABS, will the knuckle physically fit?
I have 200K on the car and the ABS need a sensor. I also need front rotors and a right front lower ball joint. I have a 90 that I replaced the rotors on about a year ago and I am going to junk anyway.
JIm
JIm
thomas4g63
Nov 20, 2011 05:08 PM
Hill4589
Mar 30, 2010 01:23 PM
slow94coupe
Jan 13, 2005 08:28 AM
