zc motor and tranny bolt right up
simple question, i know the zc motor bolts right up into 88-91 crx's with the right ecu, and fuel injectors, but does the transmission bolt right up as well without modification?
also while im asking, is there any differance between the zc and w/e transmission was usdm.
BTW IM REFERING TO SOCH ZC NOT DOCH ZC, NON-VTEC
ZC means 1.6L D series. its all interchangeable, dohc, sohc, vtec, whatever.
the only oddball D series engine is the D16A1.
but if youre getting a carburated ZC, you have to block up the port on the back of the head. itll be obvious if you do have to.
the zc tranny has shorter gears than the us trannys, it bolts up but you need to get the zc intermediate shaft, and run 90-93 integra non abs axles and take the dust ring out of the back of the hub, but yeah they work, not bad trannys, i used to have one in my rex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbp_crx »</TD></TR><TR><TD CLASS="quote">the zc tranny has shorter gears than the us trannys, it bolts up but you need to get the zc intermediate shaft, and run 90-93 integra non abs axles and take the dust ring out of the back of the hub, but yeah they work, not bad trannys, i used to have one in my rex</TD></TR></TABLE>
so i need to do some other swapping other than just the tranny itself? i need the intermediate shaft, and those axles? not just dirrect bolt on... alright, my tranny isnt bad so maybe ill just stick with mine for now, i just want a quick easy bolt up without having to go junkyard shopping
https://honda-tech.com/zerothread?id=1793626
http://tjshondas.20m.com/l3.htm
Modified by Tyson at 12:23 PM 11/15/2006
okay well thanks guys, i was thinking i would just buy the transmission while i was getting the zc anyway, but ill just put off on that for now
BrayzieEF9
Mar 2, 2010 04:22 PM
BuddhasGift2You
Nov 10, 2005 11:57 PM
