Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Phantasm USA - most items are in stock ! (4)
Old Nov 15, 2006 | 08:42 AM
PhantasmUSA's Avatar
Default Phantasm USA - most items are in stock ! (4)
AEM (30-2821) Twin Fire Ignition Module - 4 Channel
AEM’s digital Multi-Channel Twin Fire Ignition is the lightest, smallest and most cost effective ignition module on the market. This unit is available in four- and eight-channel configurations, works with O.E.M. coil-on-plug and distributed spark systems, and is ideal for applications that utilize aftermarket stand-alone engine management systems.
Our Twin Fire Ignition module is the only capacitive discharge ignition system available with dual capacitors. This enables the AEM C2DI to produce more spark energy and voltage per spark than any other available CDI unit. AEM’s exclusive Twin-Cap technology stores the energy for two distinct spark events and allows for full energy for each individual plug, including high-rpm V8s, and even on rotary engines utilizing separate leading and trailing ignition maps.
Key Features:
• 189mJ spark energy per capacitor
• 540v primary/54,000v secondary voltage energy
• Multi-Strike capability of up to 10 sparks per ignition trigger (20 degrees)
• Twin-Cap spark events are at full energy and can be simultaneous
• Smallest (5.5” x 4.625” x 1.375”) and lightest (1.5lbs) CDI on the market
• Four- or eight-channel availability
• Full spark energy with battery voltage as low as 9v
• Tachometer output included
• Extruded enclosure
Was: $350.00
Now: (In Stock, Ready to Ship!) ---> http://phantasmusa.com/aemcdi.html
Quick Stock Check ----> (919) 828-1722 ---> Talk to me on AIM = CallmeNam
D2 Racing - Full Coilover Suspension System
The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts. Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and Serviceable in the US.
D2 Racing (35% Off + Free Shipping*) Authorized Dealer
Application Guide: http://phantasmusa.com/d2racing.html
D2 Racing - Rear Camber Kit
D2 camber and toe kits provide adjustment from 0-3", a must for lowered cars. Steel mounts, polyurethane bushings and aluminum body provides the ultimate in strength, performance and weight reduction.
D2 Racing - Rear Lower Control Arms
D2 Racing lower control arms reduce unsprung weight by over 30% over your stock units. Constructed of aircraft quality 6061 aluminum and powder coated with the distinctive D2 ceramic coated purple. D2 Racing lower control arms also solve rubbing problems that can result in lowered cars with wider tires.
AEM (30-3000) Water / Methanol Injection Kit *
The Water Injection Kit is a safe and economical way to reduce air inlet temperatures to increase boost pressure for more power. Lower air inlet temperatures allow users to advance timing without having to run higher-octane fuel. This is the most complete kit available on the market straight out of the box. No additional parts required.
For use with gas engines with Forced Induction
Water Injection Key Features:
• Universal kit includes everything you need for installation
• Progressive, controller-driven 150 PSI pump
• One-gallon tank with integral fluid level sensor
• Dash light for system status and low fluid warning
• Alcohol Compatible (up to 50% in solution with water)
• Progressive controller, provides boost-dependent variable flow
• Output provided to either decrease timing or boost if the system runs out of fluid or detects an error
• Includes three jets to match your power requirement
Was: $440.00 + Shipping
Your Price + Free Shipping* : http://phantasmusa.com/aem303000.html
AeroCatch - These are absolutely the best looking & well built hood pins / latches we've ever seen.
Normal hood pins have been around for a while and work decently. Many owners hate them because they take away from the flush finish of their aftermarket carbon fiber hood. No longer is that an issue with these new hood pins!
Hood pins add an additional layer of safety for those who drive their cars at high speeds or want daily driving to be completely secure.
These AEROCATCH Hood pins fit FLUSH with the hood minimizing what you see above. The pics don't do this matching system justice, as you can see the mechanism below the hood line in our pictures. It's hard to call these just normal hoods pins when these are a race ready true latching system.
They look deceptively big... but trust me... the hardware is HIDDEN beneath the hood for the best show worthy hood pins ever. They will look fantastic next to standard Carbon Fiber, your stock paint color, AND the material they are made from is PAINTABLE! Yes, you can make them blend in almost seamlessly with whatever color you like!
Each kit comes with a template for cutting your hood to fit the pins perfectly!
These pins are SOLID, made of a 50% glass fibre reinforced engineering thermoplastic semi-crystalline material providing performance at high temperatures providing parts which are stiffer, stronger and have better heat distortion stability and chemical resistance.
AeroCatch (12-2000) Top Mounted, Non-Locking Kit
AeroCatch (12-2100) Top Mounted, Locking Kit
TopSecret Japan Sells them for ($182.00) http://www.topsecretjpn.com/ac.shtml
We have them... In Stock, Ready to Ship! ($85.00+) ---> http://phantasmusa.com/aerocatch.html
Recaro (SPD.00.000.AA11) Speed 4 Reclinable Seat - Black with White Logo
Now there is the right car seat for sporty drivers; the RECARO speed combines a sporty design and excellent lateral hold at an introductory price. For drivers with sporting ambitions who still insist on comfort.
RECARO speed is the follow-up model of the former RECARO SRD.
Standard Features:
• Belt guides 4-point or 3-point seat belts can also be used
• Specially formed shoulder support for excellent lateral hold
• Distinctive pronounced seat and backrest bolsters for lateral support even in sharp corners
• Integrated headrest for head protection
• Seat back release on both sides for simple operation
• Recline adjustment on both sides for comfortable operation
• Individual lumbar support by special cushion element for ergonomic fatigue-free seating
(Black Avus / White Logo, Seam)
Was: $700.00
Your Price: http://phantasmusa.com/spd00000aa11.html
AEM (30-1910) Fuel / Ignition Controller (FIC) *
The F/IC is a PC programmable unit that gives users with OBD-II vehicles and non-factory forced induction systems the ability to retard ignition and deliver accurate amounts of fuel without the need for outdated FMUs or “boost hiding” controllers. This system works parallel to the factory ECU preventing tuning limitations due to complex factory timing patterns and will not cause a check engine light (CEL).
Precise Fuel Delivery
The F/IC intercepts the signal to the stock injectors, allowing the user to modify pulse-width by +/-100%. The F/IC is the only piggy-back system that can decrease injector pulse-width, allowing the user to drive larger aftermarket injectors* while still maintaining proper air / fuel ratios. This powerful system can also tap into the factory injector signal and work independently to drive up to six (6) additional injectors.
Timing Retard Control
The F/IC has the ability to retard timing by intercepting and delaying the outputs from the cam and crank position sensors to the engine- with no adverse affect on applications equipped with variable cam timing. The F/IC can retard timing from the factory system based on engine RPM and load inputs.
Sensor Calibration & Control
The F/IC can also be used to recalibrate / clamp the MAF sensor, eliminating common problems with non-boosted factory MAFs. The on-board MAP sensor allows for proper fueling in boosted applications.
Plug & Play Harness (Coming Soon!)
To ease the installation of the F/IC, AEM will soon offer plug and play wiring harnesses for select applications, making the F/IC a true Plug and Play module. The first harnesses developed will be for the Nissan 350Z, Scion tC and Acura RSX.
Can-bus Systems Not Affected
Since the F/IC works in conjunction with the factory ECU, late-model vehicles equipped with a CAN-BUS system retain functionality of climate controls, dash and other components on the network.
We are the first "few dealers" that actually has this item in stock. This item is in high demand and AEM can not produce it as fast as we sell them. Order it now before it goes on backorder for another month.
Was: $450.00 + Shipping
Your Price + Free Shipping* : http://phantasmusa.com/aem301910.html
Full-Race (M-BMT3AC) Turbo Manifold - A/C Compatible *
Honda (B-Series) Engine
No reason to wait 6 weeks for these manifolds to be made. We have them in stock and ready to ship!
Was: $1200.00 + Shipping
(2 In Stock!) Your Price + Free Shipping* : http://phantasmusa.com/frmbmt3ac.html
Full-Race (M-BTA-T3) Turbo Manifold - Top Mount *
Was: $1300.00 + Shipping
(2 In Stock!) Your Price + Free Shipping* : http://phantasmusa.com/frmbtat3.html
Turbonetics (GT-K) Turbocharger
Turbonetics is proud to release the brand new line of GT-K Turbochargers. The GT-K family has been designed for maximum performance utilizing the most advanced turbocharger engineering and components.
This next generation of turbo units features special Map Enhancement Porting to allow the compressor wheel to operate at its maximum efficiency across a very broad rpm range. This variant of bleed air design, has precisely placed slots machined into the compressor housing to limit effects of surge when using large turbochargers on small displacement engines as well as providing additional air flow to make maximum horsepower at high boost pressure levels and across the entire rpm range.
Aerodynamics is what separates the GT-K turbo line from the competition. Equipped with the latest HP Compressor Wheels, designed to maximize efficiency at high boost pressures, and the F1 Turbine wheel, created to capture maximum exhaust gas energy and reduce back pressures, the GT-K family of turbos delivers unequalled performance. Turbonetics HP Compressor Wheels are made of 354 heat treated aerospace aluminum and are manufactured utilizing Hot Isostatic Processing (HIP) to allow these wheels to be incredibly strong. When paired with the Map Enhancement Porting of the GT-K compressor housings, these wheels flow huge volumes of air at high pressure ratios while still delivering a cool efficient intake charge.
The F1 Turbines are a new generation of 10 bladed, tall tip height wheels that allow you to turn up the boost without encountering dreadful backpressure issues. Made from 713C Inconel and balanced to Turbonetics exacting standards, these wheels match up with the HP Compressor Wheels to make the best turbocharger combination available.
Turbonetics exclusive Black-Chrome Perma-Coating also comes standard for heat reflection away from the compressor housing to aid in lowering compressor wheel inlet temperatures and gives these units great looks to match their performance. Select turbo systems will also be able to be upgraded to the GT-K Turbos if so desired.
Turbine housings will feature high temperature ceramic coating to trap exhaust gas energy inside the turbine housing for greater energy delivery and faster response time, as well as keeping the engine compartment temperatures low. Cooler under hood temps means more power potential from a cooler compressor intake charge.
In Stock ---> Turbonetics (11257) GT-K 325 Turbocharger ---> Horsepower Rating: 275-375
In Stock ---> Turbonetics (11258) GT-K 350 Turbocharger ---> Horsepower Rating: 300-400
In Stock ---> Turbonetics (11259) GT-K 450 Turbocharger ---> Horsepower Rating: 375-475
In Stock ---> Turbonetics (11260) GT-K 500 Turbocharger ---> Horsepower Rating: 450-550
In Stock ---> Turbonetics (11262) GT-K 650 Turbocharger ---> Horsepower Rating: 575-700
In Stock ---> Turbonetics (11263) GT-K 850 Turbocharger ---> Horsepower Rating: 700-875
In Stock ---> Turbonetics (11264) GT-K 1000 Turbocharger ---> Horsepower Rating: 800-1000
Your Price: http://phantasmusa.com/turbonetics.html
AEM’s Plug & Play Engine Management System (EMS) will forever change the way you look at and perform fuel injection tuning! This user-programmable system plugs directly into a vehicle’s factory ECU harness and requires no additional wiring or hardware. (Some adapting hardware may be required for non-factory forced induction vehicles.) Windows™-based software (2000, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configurable and enable tuners to establish “quick keys” to any pertinent information during the tuning process. The AEM EMS’s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
• Installs in Minutes • Plug & Play Technology - No Wiring Necessary • Uses all the Factory Sensors • Fuel Table Automapping • Base Maps Included • Programmable Traction Control • Onboard 512kb Datalogger • 10 Cyl Sequential Fuel Injection • 16 General Purpose Outputs • 7 Definable Switch Inputs • Electronic Boost Control • Soft Cut Rev Limiters • 2 Step Launch Control • Wet or Dry Nitrous Control • Definable Knock Control • Full Idle Control • 4 EGT Inputs w/Fuel Control • 16/32 Hybrid High-Speed Processor
AEM - EMS computer are on SALE for all vehicles... Talk to me for if you are serious.
AEM (30-4100) Wideband UEGO Gauge Kit *
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2 1/16 inch) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
No laptop required for monitoring ! Bosch UEGO sensor included !
Was: $350.00 + Shipping
Your Price + Free Shipping* : http://phantasmusa.com/digitalgauges.html
AEM (30-4350) Boost Controller Gauge Kit *
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface.
There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
AEM (30-4300) Serial Data Gauge - 19 Channel *
AEM's Serial Gauge plugs into the company's Programmable EMS and has the ability to read 19 channels simultaneously to provide reference for all outputs, including boost, AFR, EGT, H2O, IAT, knock, volts, RPM, vehicle speed, and more! Since it can read all channels at once, AEM's Serial Gauge eliminates the need to buy a cluster of gauges, or you can link multiple Serial Gauges together to monitor additional channels or to divide your readouts across a few gauges.
AEM's Serial Gauge includes interchangeable silver and black bezels and pin guides, and black and white faces for a customizable look. Quick-Connect technology allows you to install the gauge and connect the wiring separately for easy installation and less chance of damage to the circuit board. The Serial Gauge includes a harness, wiring to connect to the EMS, a daisy-chain adapter for linking multiple gauges to one EMS and software for a trouble-free installation.
AEM (30-4400) Four-in-One / Voltmeter Gauge *
AEM’s digital Voltmeter display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
AEM’s digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels and black and white faceplates to personalize the look of your gauge - it’s like having four gauge designs in one! A complete gauge system that includes a sensor and requires no additional parts.
Was: $120.00 + Shipping
AEM (30-4401) Four-in-One / Pressure Gauge *
AEM’s digital Oil Pressure display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
(Oil or Fuel)
Was: $235.00 + Shipping
AEM (30-4402) Four-in-One / Temperature Gauge *
AEM’s digital Oil Temperature display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
(Oil, Transmission, or Water)
Was: $175.00 + Shipping
AEM (30-4406) Four-in-One / Boost Display Gauge *
AEM’s digital Boost display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
(50 psi Boost / -30 Vacuum)
SEIBON (-25% Off) Any Carbon Fiber Products
We are an Authorized Dealer for SEIBON Carbon Fiber Products, so you are getting really high quality parts with Excellant Fitment.
Look up your items with pictures: http://www.SeibonCarbon.com
Price Sheet ---> http://www.seiboncarbon.com/fi...6.pdf
Thats right, you get (-25% Off MSRP) any item on the SEIBON Price Sheet, but you have pay the Freight Company for shipping. These items are too big to be shipped in by UPS, FEDEX, or USPS. Freight Truck Shipping Rates are as follow.
Carbon Fiber Hood or Trunk
$150.00 Freight Truck Shipping to ---> Phantasm
$200.00 Freight Truck Shipping to ---> Your House
Carbon Fiber Lips (Front, Side, Rear)
$100.00 Freight Truck Shipping to ---> Phantasm
$150.00 Freight Truck Shipping to ---> Your House
Tomioka Racing (Super Slopes) Low Down Service Ramps
Tomioka Racing Super Slopes are designed to help reach jack points by raising your vehicle up to 2.5 inches in height. These TR Super Slopes are the perfect for those lowered vehicles. Same Design as the "orginal" Takata Low Down Service Ramps.
Was: $100.00
Now: (In stock, Ready to Ship!) http://phantasmusa.com/tomiokaracing.html
Takata Racing Harnesses
From a global leader in automotive safety systems comes Takata Racing Harnesses. Takata has the experience and technology needed to provide Formula-1 quality safety harnesses. A racing saftey restraint system approved by FIA 8853/98 and 8854/98, the Takata racing harness is the racing safety equipment of choice for many professional race car drivers.
This true competition racing harness will not only catch the eye of any bystander with its trademark green color, but also protect and secure a driver in his seat even under the most extreme conditions. If you are looking for high quality, FIA certified, super safe and eye-cathcing racing harness, look no further. TAKATA is your answer.
Was: $400.00 + Shipping
Your Price: http://phantasmusa.com/takata.html
Everything from Omni Power is... In Stock
Your Price + Free Shipping* : http://phantasmusa.com/omnipower.html
GReddy (12001400) Universal Intercooler - SPEC M *
GReddy Bar and Plate Intercoolers are designed and built to provide superior cooling efficiency and overall durability compared to tube and fin style intercoolers, resulting in these cores being suitable for even the most extreme racing conditions.
Authentic Greddy Product ! (Core Size: 24.0" L x 7.5" H x 3.0" D) 2.25" Inlet
Was: $240.00
Your Price: http://phantasmusa.com/greddy12001401.html
Authentic Greddy Product ! (Core Size: 23.6" L x 11.0" H x 3.0" D) 2.75" Inlet
Was: $270.00
Your Price: http://phantasmusa.com/greddy12001400.html
Omni Power (Front) Big Brake Kit *
• Greatly Decreased Stopping Distances
• Very Minimal Brake Fade If Any
• Firmer Pedal Feel
• Deeper Corner Braking
• Better Lap Times At The Track
Package Includes: (2) 4 Piston Brake Calipers, (2) Sets Front High Performance Brake Pads, (2) 300mm Cross Drilled & Slotted Rotors, (2) Front Stainless Steel Braided Brake Lines, (2) Mounting Brackets, All mounting hardware.
Now: $900.00 + Free Shipping* : http://phantasmusa.com/omnipower.html
Innovate (3723) LM1 Wideband Meter - Basic Kit *
This is the only way to safely "Street Tune" your car if you don’t put it on a Dyno.
Universal - Will work with all applications. (All Motor, Turbo, Nitrous, and Supercharger).
Was: $349.00
Your Price: http://phantasmusa.com/lm1wideband.html
Vibrant (Universal) Stealth Muffler - Flat Black *
Black Wrinkle Painted Muffler without the chrome for that hidden stealth look! Choose from:
2.25 inch (inlet) 5" x 9" x 15"
2.50 inch (inlet) 5" x 9" x 15"
3.00 inch (inlet) 5" x 9" x 15"
Was: $119.95 + Shipping
Now: $100.00 + Free Shipping* : http://www.phantasmusa.com/vibrant.html
<FONT COLOR="Red">* FREE SHIPPING is only available to the 48 States.</FONT>
Browse through our website for additional items. (www.PhantasmUSA.com)
Modified by PhantasmUSA at 2:06 AM 8/28/2007
Old Nov 19, 2006 | 02:12 PM
Default Re: Phantasm USA - most items are in stock ! (PhantasmUSA)
Questions? Talk to me to me on AIM = CallmeNam
Old Nov 29, 2006 | 10:35 PM
Bump #151
Old Dec 4, 2006 | 01:24 AM
Bump #191
Old Dec 6, 2006 | 01:53 PM
Bump #227
Old Dec 11, 2006 | 11:12 PM
Bump #276
Old Dec 18, 2006 | 06:24 PM
Bump #345
Old Jan 3, 2007 | 11:04 PM
Bump #442
Old Jan 9, 2007 | 09:33 AM
ludedeg's Avatar
Bump for Nam! Great guy and has more items in stock than most other companies.
Old Jan 15, 2007 | 03:49 PM
Default Re: (ludedeg)
Bump #544
Old Jan 22, 2007 | 07:49 PM
Default Re: (PhantasmUSA)
Bump # 673
Old Jan 28, 2007 | 12:18 PM
Bump # 785
Old Feb 1, 2007 | 09:21 AM
Bump # 851
Old Feb 5, 2007 | 12:40 PM
Bump # 915
Old Feb 10, 2007 | 01:53 PM
Bump # 975
Old Feb 10, 2007 | 05:50 PM
hamda's Avatar
for takatas!!!
Old Mar 28, 2007 | 08:04 AM
ludedeg's Avatar
TTT for a great seller... Lots of product knowledge
Old Jul 2, 2007 | 10:10 PM
New Items -----&gt; In Stock
Bump # 1159
Old Jul 13, 2007 | 11:46 AM
More New Items Added
Bump # 1176
Old Jul 13, 2007 | 01:56 PM
EK_vzla's Avatar
great service, fast shipp, bump for GREAT prices
Old Jul 18, 2007 | 09:13 PM
Default Re: (ARAXIS)
Bump # 1235
complete online catalog ---&gt; http://www.PhantasmUSA.com
Old Jul 23, 2007 | 12:12 PM
Bump # 1301
please check out our... Online Catalog http://www.PhantasmUSA.com
Old Jul 25, 2007 | 09:18 AM
ghostofnyc's Avatar
bump for nam and hung
Old Jul 28, 2007 | 10:04 AM
Bump # 1385
Old Jul 28, 2007 | 06:46 PM
S2000Forsale's Avatar
do you carry just the wide band controller, with out the gauge?
