rpm shoots up then drops when let off gas
hi i have a 93 Ls with a ys1 tranny (non-Lsd) and minor bolt on's.the problem is after i like get on it pretty hard and then slow down again the car seem like it dosent want to stay in gear but it is.The rmp's shoot up then drop when i let off the gas back to normal it only happens in 2-5 gear not in first tho and the clutch smells real bad after.iv asked people around they say it is the clutch ,some say its gettin to much fuel do u guys no whats wrong.also i havent got a tune up scence i got the car.mabe its off time?
i also put in 89 octain
imma take a guess and say that your clutch is going bad if it slips in and out like that. That actually happened to me and i changed my clutch adn everything was good again. Also If you have a short shifter you might not be putting it in gear all the way and it slips out just enough to do the things your saying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC TWOin IT »</TD></TR><TR><TD CLASS="quote">imma take a guess and say that your clutch is going bad if it slips in and out like that. That actually happened to me and i changed my clutch adn everything was good again. Also If you have a short shifter you might not be putting it in gear all the way and it slips out just enough to do the things your saying.</TD></TR></TABLE>i dont have a short shifter no boot also but ok i guess ill look into purching a clutch kit.
yeegsr
14
May 17, 2007 05:25 AM
SilverPanda
May 28, 2005 10:20 AM
