Suspension & Brakes Theory, alignment, spring rates....
23mm sway questions
Old Nov 15, 2006 | 08:16 AM
Boomer234's Avatar
Default 23mm sway questions
i've searched high a low but i can't find anywhere that has 23mm sway bar bushing brackets and endlinks
anyone know? thanks in advance
Old Nov 15, 2006 | 08:52 AM
nonsense's Avatar
Default Re: 23mm sway questions (Boomer234)
Summit has the bushings
http://store.summitracing.com/...w=sku
for endlinks, it depends on what car you're installing it on
Old Nov 15, 2006 | 10:15 AM
Boomer234's Avatar
thanks, didn't think of summit
its going onto a '00 Si, which endlinks should i use?
Old Nov 15, 2006 | 10:48 AM
nonsense's Avatar
Default Re: (Boomer234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boomer234 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, didn't think of summit
its going onto a '00 Si, which endlinks should i use?</TD></TR></TABLE>
The stock Si ones should work, but you may need to get some metal inserts from a-spec racing. Are you using something for subframe reinforcement?
Old Nov 15, 2006 | 11:10 AM
Boomer234's Avatar
thanks for the help
yes, i have a beaks reinforcement kit
Old Nov 17, 2006 | 11:48 AM
jDM_STyLe_Dc2's Avatar
passwordjdm might have them.. i know they have some for itr sway ..but if its 23mm they should work no matter what car....also check energy suspension bushings
Old Nov 17, 2006 | 12:08 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boomer234 &raquo;</TD></TR><TR><TD CLASS="quote">yes, i have a beaks reinforcement kit</TD></TR></TABLE>
you might want to look into more protection than that. There have been some people who've had subframe's tear out with the beaks and 22mm rear sways. Check out http://www.asrparts.com
Deano_D aka "Brick Top"
Jul 25, 2007 11:25 AM
EMphaticONE
Nov 25, 2004 08:57 AM
JforJonathan
Apr 18, 2004 07:48 PM
ransack
Sep 24, 2003 05:07 PM
xhatchracerx
Apr 10, 2003 06:57 AM
