Suspension & Brakes Theory, alignment, spring rates....
Noob Question on Coil-overs
Old Nov 14, 2006 | 07:13 PM
mcgee*'s Avatar
Cigarette Squad
Default Noob Question on Coil-overs
I searched hush...
Anyone send me on my way to a step by step on how to lower the coil overs on car i just got?
Old Nov 14, 2006 | 08:13 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: Noob Question on Coil-overs (Bangin')
couldnt find anything on google just how to install them
im pretty sure its simple but looking for the correct way to do it.
Old Nov 14, 2006 | 08:34 PM
slow_ls's Avatar
You loosen the lock nut and then you spin the top nut clock wise to lower and vise versa for raising. And of course this is with the car in the air.
Old Nov 14, 2006 | 09:30 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (slow_ls)
so whats that weired looking tool that came with it for? too loosen the lock nut?
and wheres lock nut located
Old Nov 14, 2006 | 11:52 PM
blackdelslo's Avatar
Default Re: (Bangin')
Right underneath the coil spring are two big thick washer looking things, they have notches in them for the weird semi circle tools to grab onto and tighten or loosen. The actual process of using the tools is kind of awkard so just place around with it.
Old Nov 15, 2006 | 09:32 AM
PIC Performance's Avatar
They are usually called spanner wrenches, and you usually receive them in pairs, one smaller than the other. The larger one is for the spring perch, the smaller one is for the spring perch locking collar.
You fit the larger one around the spring perch, and the smaller around the locking collar, and tighten them against each other (turn the spring perch clockwise, towards your left and turn the locking collar counter-clockwise, towards your right) as tight as you can get them. THen when you turn one of them, the other will turn in the same direction, and the entire shock body will spin as well.
Before adjusting height, loosen the lower mount collar (the bottom most ring, sitting against the lower mount). To raise, the corner up, you turn the spring perch clockwise To lower, you turn locking collar counter-clockwise. Make sure you re-tighten the lower mount collar after you are done.
Old Nov 15, 2006 | 09:57 AM
mcgee*'s Avatar
Cigarette Squad
Default Re: (PIC Performance)
thanks!
CubbyChowder
May 6, 2010 01:50 PM
NHswaps13203
Suspension & Brakes
Apr 27, 2008 11:23 AM
Teglessb18
Suspension & Brakes
Feb 9, 2006 10:29 AM
PIC Performance
Suspension & Brakes
36
Mar 14, 2005 03:09 PM
DoctorGSR
Suspension & Brakes
17
Mar 6, 2005 06:52 PM
