4x114 Conversion on DA
not very useful, but it can be done. my friend is interested in doing the same suspension on his da. all i can remember is that you have to use different parts, so its not a bolt-up affair.
rear trailing arms bolt up
for the fronts you need new DA bearings and only the 4 x 114 hubs (with the inner race still stuck on it).
Also remove the inner race from the 4 x 114 bearings ( so you should have a total of 4 bearing races 2 in your hand 2 on the hubs).
Press out old bearings from DA knuckles and replace with new bearings (remove all 4 inner races from new bearings)
Now pop in the old races from the 4 x 114 knuckle and press everything together and your done. Worked on 90 civic si w/ DA knuckles.
i beleive it is the same as doing the 5-lug swap on a DA
read this, it is very informative and tells you exactly how to do it with the 5-lug:
http://www.technet.ff-squad.com/how-to/5lug.ef-da/
you have to shave the hubs for the 5-lug, so i would think you have to do the same for the 96 ITR.
i just got 4x114.3 suspension for my DA, after talking to some people i'm going to try using the type r front knuckle (even though it says not to). the vertices seem to be the same and it will just throw off the caster and camber. the camber should actualy be better if your car is lowered, it won't be as negative (like having a camber kit). also i can adjust the caster, so i should be able to tune out any caster problems. i am going to see how it works. hopefully it will work and any suspension problems will be able to be tuned out, if not i will just do it how the write up says and use the DA knuckles. i will probably do it on sunday.
I am in sacramento as well, so if you need anything let me know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky »</TD></TR><TR><TD CLASS="quote">Why not just get a different set of wheels? Sounds like a ridiculous amount of trouble for such a petty thing.</TD></TR></TABLE>
after doing this **** with 4 lug and 5 lug on my DA and EF ....i would have rather just bought some nice wheels and a fast brake kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heron of Alexandria »</TD></TR><TR><TD CLASS="quote">
after doing this **** with 4 lug and 5 lug on my DA and EF ....i would have rather just bought some nice wheels and a fast brake kit.</TD></TR></TABLE>
word. without abs it won't help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmellsLikeMustand »</TD></TR><TR><TD CLASS="quote">word. without abs it won't help.
Well, depends what you're doing with the car. A track car will definitely benefit from a bigger heat source, and will have less brake fade potentially. A street car, yeah, not necessary.
</TD></TR></TABLE>Well, depends what you're doing with the car. A track car will definitely benefit from a bigger heat source, and will have less brake fade potentially. A street car, yeah, not necessary.
s1ngle
29
May 9, 2012 03:48 PM
JinMTVT
10
Nov 28, 2001 04:45 PM
