REAR DISC BRAKE CONVERSION QUESTION ???
was wondering when doing a rear disc brake conversion, can i use 89-00 acura integra?? some dude offer me a deal on a 90 integra rear disc brake and a 94 integra disc brake. some how the 94 was a little bit expensive. any insights on the differences?? or is it just the same?? its going on a 95 civic coupe.
They will both work. Only difference is in trailing arm bushing diameter. However, I'm not sure if the 90 ebrake cables will be at an appropriate length. You can buy the 94, because I know the ebrake cables will work.
so the trailer arm will not work. better off just paying a little more for the 94 integra then. or can i just replace the old bushings with the new 94's ??? any thoughts anyone.
The trailing arm will bolt on. I just don't know if the 90 Integra ebrake cable will work. I know for sure the 94 Integra ebrake cable will work.
nickwilmot
Aug 27, 2003 08:42 PM
